It is currently Tue Sep 22, 2026 6:25 pm
PostPosted: Sun Jan 17, 2021 8:04 pm
Location: I'm hiding in Honduras -I'm a desperate man -Send lawyers, guns & money The shit has hit the fan
I have a lic, and picked up a Midland MXT115
I have not really done much else with it.
Anyone else using the repeaters, and what are the good ones?
Respond on Tac 3
PostPosted: Tue Jan 19, 2021 7:24 am
I've tinkered with it using Motorola XPR's and CDM's with Allstar Link. We have some local groups who use it for neighborhood wildfire evac. Out here repeater usage is mixed, some are relatively quiet while others sound like CB.
PostPosted: Thu Jan 21, 2021 1:46 am
There's a new radio for GMRS users: https://www.buytwowayradios.com/wouxun-kg-1000g.html
PostPosted: Thu Jan 21, 2021 8:06 am
“This 50 watt powerhouse...”
Exceeds FCC rule by x2?
PostPosted: Thu Jan 21, 2021 10:16 am
You can run 50 watts on GMRS
https://en.wikipedia.org/wiki/General_M ... io_Service
GMRS
462.5500 MHz 15 50 W 20 kHz (2)(5)
462.5750 MHz 16 50 W 20 kHz (2)(5)
462.6000 MHz 17 50 W 20 kHz (2)(5)
462.6250 MHz 18 50 W 20 kHz (2)(5)
462.6500 MHz 19 50 W 20 kHz (2)(5)
462.6750 MHz 20 50 W 20 kHz (2)(5)(7)
462.7000 MHz 21 50 W 20 kHz (2)(5)
462.7250 MHz 22 50 W 20 kHz (2)(5)
467.5500 MHz 50 W 20 kHz (3)(5)
467.5750 MHz 50 W 20 kHz (3)(5)
467.6000 MHz 50 W 20 kHz (3)(5)
467.6250 MHz 50 W 20 kHz (3)(5)
467.6500 MHz 50 W 20 kHz (3)(5)
467.6750 MHz 50 W 20 kHz (3)(5)
467.7000 MHz 50 W 20 kHz (3)(5)
467.7250 MHz 50 W 20 kHz (3)(5)
Table Notes
(1) Shared FRS and GMRS simplex.
(2) Shared FRS and GMRS simplex; GMRS repeater output.
(3) GMRS repeater input. The output frequency of this repeater input is the input frequency minus 5 MHz.
(4) FRS transmissions are limited to bandwidth of 11 kHz with a transmitter deviation of +/- 2.5 kHz. Channels are on 12.5 kHz centers.
(5) GMRS transmissions may have a bandwidth of 16 kHz with a transmitter deviation of +/- 5.0 kHz. Channels are on 25 kHz centers.
(6) GMRS transmissions are limited to a bandwidth of 11 kHz with a transmitter deviation of +/- 2.5 kHz. Channels are on 12.5 kHz centers.
(7) National GMRS calling channel (CTCSS tone 141.3 Hz).
PostPosted: Thu Jan 21, 2021 12:02 pm
My bad, I always thought it was 25, thanks Jim!
PostPosted: Thu Jan 21, 2021 2:37 pm
And you need a license!
