It is currently Tue Sep 22, 2026 8:09 pm
 Post subject: COVID Watch Net
PostPosted: Sat Mar 14, 2020 1:28 pm
Pri Freq – 14.308Mhz USB (yep that 308)
Sec Freq – 14.311Mhz USB (Up 3Khz)**
Alt Freq – 14.314Mhz LSB (up 3Khz)**
Start time – 2200Z Fri 13 Mar (Fri 1700 CDT)
**Net Control Station (NCS) moves to Sec Freq if Pri freq is occupied or splatter is occurring at the NCS location. In the event the Sec freq is occupied or is unworkable continue up to Alt frequency.
If Sec freq is used start time will be 2205z and if conditions require the Alt freq use then start time will be 2210z.
Minor adjustments in freq may be required based on freq usage by other operators or other nets.
