It is currently Tue Sep 22, 2026 5:51 pm
 Post subject: Whistler TRX-1 numb?
PostPosted: Wed Mar 13, 2019 5:31 am
Seems like the Cencom fire frequencies have become so faint they won't even break squelch. Cencom police work fine, and other radios don't have a problem. Anyone have an idea why? I'm currently trying different antennas, RTFM, etc.
 Post subject: Re: Whistler TRX-1 numb?
PostPosted: Wed Mar 13, 2019 6:51 am
Sounds like an issue on their end if the rest of the stuff is fine.
PostPosted: Wed Mar 13, 2019 2:05 pm
kc6pqe wrote:
Seems like the Cencom..
Kitsap911? This is the amateur radio forum btw..
(not Cencom anymore.)
If so LE is repeated on most of their channels. Fire is only repeated on f-2. Rest are simplex.
PostPosted: Wed Mar 13, 2019 7:40 pm
If a guy were about to buy a receiver like this one, would you buy the TRX or a different make / model?
Asking for a dude
PostPosted: Thu Mar 14, 2019 7:50 am
I guess I forgot they were renamed a couple of years ago, thanks. The dispatchers still refer to cencom constantly, tho.
I posted here because I noticed the posts were more recent and I was hoping for a reasonably rapid reply--which I did get, thanks.
As for the TRX-1, I bought it because it seemed to have a more sensitive receiver than the 436. I run it 12 hours a day on a USB charger, batteries removed. Works fine. I think the initial programming is excruciatingly difficult, but once it's done, it's done.
I am starting to think my reception problem is a matter of antenna orientation, as chpalmer mentioned, Fire1 is simplex.
PostPosted: Thu Jun 27, 2019 3:39 pm
Asking for a dude
That would depend on what the person is trying to monitor/listen. The TRX-1 will receive DMR,P25 (trunked and non trucked), NXDN and IDAS if I read the specifications correctly. They won't, however, receive DSTAR, or Fusion. So it would depend on the application the person getting the receiver is wanting to monitor. I know ICOM receivers will be able to hear DSTAR but, not Fusion. Not sure about P25, NXDN or IDAS. I don't think they can listen to DMR or Trunked radio systems digital or analog, assuming I am reading the product brochure right.
Good Luck
