It is currently Thu Aug 13, 2026 7:46 am
 Post subject: Free Antenna
PostPosted: Wed Oct 03, 2012 7:28 am
Happen to come across this post on Craigslist. Someone here may be interested.
http://seattle.craigslist.org/est/zip/3307417408.html
 Post subject: Re: Free Antenna
PostPosted: Wed Oct 03, 2012 9:26 am
Looks like an old 11 meter antenna, perhaps a HyGain CLR2 or Antenna Specialists M118 Super Magnum.
PostPosted: Wed Oct 03, 2012 10:52 am
The hardware might be good to have.
PostPosted: Wed Oct 03, 2012 11:21 am
Guy I work with is interested. Told him I would help him pick it up. Assuming it's still available.
PostPosted: Wed Oct 03, 2012 10:01 pm
Those old aluminum 5/8 wave CB groundplanes will play just fine on 10 meters when you shorten up the vertical piece... I have heard that the CLR2's don't take Ham power levels, same could be said for whatever Radio Shack was selling a quarter century ago... but other matching methods could be employed if the tapped coil in the plastic insulator base where the connector is mounted has "failed open"...
