It is currently Thu Aug 13, 2026 8:15 pm
 Post subject: Grid Square hopping
PostPosted: Thu Sep 27, 2012 9:49 pm
Thinking I might do some weird grid square traveling in my van. Getting ready to be able to put my 746 (non-pro) in the van. Wondering about antennas. Thinking about a screw antenna maybe mounted to the trailer receiver. I don't want something perminant as I still hope to date some day:) Also thinking of a thing on the luggage rack that will lift antennas from laying on the roof to vertical with the flip of a button, but pricey and my step-son is a welder so got me thinking about the hitch as the mount.
First time I transmit with 100w will my Sienna cease to function?
 Post subject: Re: Grid Square hopping
PostPosted: Fri Sep 28, 2012 6:51 am
Putting your feedpoint that close to ground is a bad idea, not to mention you could have near-field problems with the coil and whip that close to the vehicle body. Here is a good explanation as to why: http://www.k0bg.com/gpnotes.html
PostPosted: Fri Sep 28, 2012 9:23 am
With the hitch I was thinking that I could have the antenna start at the hight of the van roof mounted on a bar that 90's into the hitch??
PostPosted: Fri Sep 28, 2012 11:46 am
That could work but might make for some strange grounding issues without the feedpoint being strapped to the body.
PostPosted: Fri Sep 28, 2012 1:50 pm
So no option. I go mobile HF, or date...
PostPosted: Fri Sep 28, 2012 5:46 pm
Curious what contests/awards deal with Maidenhead Grids on HF? Now 6 meters and up, that's a whole different story 8)
Antenna mounting is not really an issue if you obtain a "QST" vehicle (devoted entirely to amateur radio) and drive whatever else on the "dates"...
Eric
KB7DQH
PostPosted: Sat Sep 29, 2012 8:17 am
Here's a link to Tarheel Antennas. They sell the screwdriver type antenna and all the stuff needed to mount them to vehicles. This link specifically has pictures of van installations. There are other types of installation photos available also.
http://www.tarheelantennas.com/van_photos
Jeff KB7AIL CN88
