It is currently Mon Sep 21, 2026 1:00 pm
 Post subject: WB0CZA Repeater System
PostPosted: Thu May 24, 2012 5:29 pm
The WB0CZA repeater system is starting to come back together...
441.125 and 927.400 123pl now on Buck Mt. over Quilcene. Just shy of the 4000 ft line.
[strike]The 900mhz receiver is not up correctly quite yet but Ill hopefully make a trip back up in the morning and see why.[/strike]
PostPosted: Thu May 24, 2012 10:17 pm
I am under the impression that the road is free enough of that white cold slippery stuff to permit vehicular access???
PostPosted: Fri May 25, 2012 8:06 am
Yep- 2 weeks ago I was headed off at the pass (Rocky Brook Pass) but yesterday not a stick of it on the road. Some in patches off the side of the hill still there to prove it was there I guess... :mrgreen:
PostPosted: Fri May 25, 2012 10:48 pm
900 RX should be good to go...
The mountain top can almost be seen glowing when this repeater keys up... :mrgreen:
Ill post a coverage map of the 900 once Ive rested a bit... 2 trips up and back today.
PostPosted: Sat May 26, 2012 1:40 pm
I just heard someone key up on the 927.4 system and the callsign was transmitted back. :)
PostPosted: Sat May 26, 2012 3:20 pm
Its a crossband type system so whatever happens on the 440 side also happens on the 900 side. :wink:
I just dusted off my 900 GTX and need to install it somewhere now... Im thinking here at the house.
Got my start with a 900 system so kinda partial. :mrgreen:
PostPosted: Sun May 27, 2012 7:57 am
This used to be a multi-site simulcast system, but I get the impression it's just a single site now.
Correct?
PostPosted: Sun May 27, 2012 10:56 am
Correct?
There are two sites up right now... Stampede Pass and Buck Mt... (in fact I just heard Bryon on the east side working stampede.)
The plan is to turn up a couple more full sites and some extra receiver sites.
Port Angeles is next on the list...
edit- And now Bryon working 900 from a portable I-90 to midspan 520 on the lake full quieting most of the time...
PostPosted: Sun May 27, 2012 12:51 pm
PostPosted: Mon May 28, 2012 9:51 am
If this is the one I'm thinking of it's always been a great repeater for doing anything from North Bend on east.
PostPosted: Sat Jun 02, 2012 11:08 pm
Glad to hear you got the Stampede Pass repeater back up. I've worked that one before from Ryegrass. I've actually been listening to it the past couple of days here at home and it does sound alot better. Kudos!!!
PostPosted: Sat Aug 25, 2012 2:08 pm
This repeater routinely sounds better on my handheld than the "other" 440 box I've been using for years (444.300, also on Buck).
And, it's quieter, too.
May have to switch over to this one full time, especially with the addition of other sites and receivers.
Thanks for your work on this.
Brad.
PostPosted: Fri Aug 16, 2013 7:53 pm
Chris - is this system still in the same configuration as last year? I just talked to Kenny/KU7M, and he thought the 900 side was on West Tiger.....?
My experience with the 900 side would suggest Buck....
Brad.
PostPosted: Fri Aug 16, 2013 8:29 pm
Its all on Buck now. Tiger might be a 70cm receiver eventually.
Buck is a split antenna system with a hi-gain Bogner antenna (12dbd ish) and a 10db transmit antenna with roughly 200watts at the transmit port before the cans.
PostPosted: Fri Jul 18, 2014 7:36 pm
Well.....
UHF and 900 both appear to be off the air. Technical problem, or was the equipment pulled?
I think the UHF side was having receiver issues of late....
Brad.
