It is currently Mon Aug 31, 2026 3:49 pm
 Post subject: ROS digital mode
PostPosted: Tue Feb 23, 2010 10:27 am
anyone following that ROS digital mode stuff, see how meny people just use it all over with no regard to rules haha. wonder how long till we can use S.S. on HF haha... If anyone happened to tune into 14.101 it was a total mess I was never able to decode anything properly.
one of 10 million links
http://www.eham.net/articles/23410
the software is getting hard to locate if you cant find a copy let me know I can UL somewhere but remember to TX in USA (right now)
 Post subject: Re: ROS digital mode
PostPosted: Tue Feb 23, 2010 2:48 pm
Found this...
http://blog.g4ilo.com/2010/02/hot-news- ... al-in.html
PostPosted: Tue Feb 23, 2010 2:52 pm
I'm sure things will be changed to accommodate this mode.
PostPosted: Tue Feb 23, 2010 3:19 pm
I am still on the fence about this one(if in fact its considered SS), see the problem is that people tend to run these low power modes at full power, you get 20 people running 100w of SS in 2300hz of bandwidth you have a giant black hole on the HF band that people can use.
if you then leave the "calling frequency" then you interrupt everything else with random 100w or more blips and boops covering 2250hz poor CW users.
BTW official site is here... http://rosmodem.wordpress.com/
sound clip of the mode is also on that site.
debate is good all over as it is argued that the transmission mode is FSK and not SS sooo this debate will go on for a while, it sounds like.
edit: check out this post, he wrote a good letter to the FCC asking whats up. - fun debate that the author screwed the pooch by using possibly the term "SS" incorrectly.
http://forums.qrz.com/showpost.php?p=18 ... stcount=48
PostPosted: Wed Mar 03, 2010 12:22 pm
looks like ROS has been declassified as SS and is now under RTTY classification for FCC rules.
All safe to blast out and blanket HF with 100w of boop beep bop again.
PostPosted: Fri Mar 05, 2010 9:10 am
illegal again
http://www.arrl.org/news/stories/2010/03/04/11377/?nc=1
