It is currently Fri Aug 14, 2026 5:50 pm
PostPosted: Thu Feb 04, 2010 5:42 pm
I wasn't aware of these forums before (shame on me) but now I am. I note the amateur radio repeater frequencies are badly out of date. Here are the major updates for my county:
NJ: Burlington County: Amateur Radio
update
145.150 -> now K2AX moved to Camden County: Winslow Twp - PL 91.5
145.290 K2AA -> PL 91.5
145.470 - call now KC2QVT - PL 127.3
146.925 WB2YGO -> PL 131.8
147.150 -> call now KC2QVT - PL 127.3
224.860 -> call now K2JZO - PL 131.8
442.050 WB2YGO -> PL 118.8
448.325 -> call now KC2QVT - PL 127.3
449.025 -> call now K2JZO moved to Bordentown - PL 203.5
add
224.300 127.3 R - - Browns Mills N2RDM
delete
449.925 -> WA1AOR moved to SC
If you want to get the current info on sNJ and ePA: http://arcc-inc.org/
If you want most of the east coast coordination council pages: http://mysite.verizon.net/trscons/bm_ar_fm.html
Hope this helps.
PostPosted: Thu Feb 04, 2010 6:30 pm
Thanks. All updated with your info (except 448.325 as I didn't see a listing for it in Burlington county).
PostPosted: Thu Feb 04, 2010 9:48 pm
OK. 145.470 Chatsworth, 147.150 Westampton, and 448.325 Westampton are all county OEM/ARES repeaters, all with a PL of 127.3 and a call of KC2QVT (ex-WB2SOY). And I forgot to add 147.105 KX2D PL 71.0 Bordentown, not in Robbinsville, Mercer county as listed in the db. Also, delete 440.425 Browns Mill WR2MSN and 445.275 Bordentown K2RFI; RFI moved to FL. And for PA, DE, NJ and MD all WA3BXW repeaters are now W3BXW. I do the Web site -- http://w3bxw.com/ -- that describes the entire linked system that covers NYC to DC, sMD and w to Harrisburg, a huge area. And the two K2NI repeaters should be listed as Monmouth county. not Burlington.
73, Tom W2XQ
PostPosted: Fri Feb 05, 2010 7:53 am
Thanks. All updated with your info. If anyone has the repeater lat/lon our database can also output the repeaters on a map like this:
http://interceptradio.com/s.php?sfreq=4&sstate=WA&ssvc=HAM&cmap=1&cfreq=1&cpl=1&stype=R&ccounty=1&ccity=1&ccall=1&cnotes=1&z=1
Holding the mouse over any repeater location will show the callsign/PL and any other information.
