It is currently Sat Sep 19, 2026 11:38 am
 Post subject: RCI-2950
PostPosted: Wed Sep 22, 2004 4:38 pm
I have a RCI-2950 radio that I used for CB 7 years ago and still have it. Can anybody tell me or point me in the right direction to set it up back as a 10 Meter radio again.
Thanks for the Help.
Michael R.
AD7TH
PostPosted: Thu Sep 23, 2004 4:47 pm
Locate the PCB which has the jumpers on it (it is behind the front panel)
Find jumper J2, you will notice that it is on pins P3 and P4 (origional, this is the Stock setting)
If you remove it you will have coverage from 26.000-29.700 MHz
If you place it on pins P1 and P2 you will have coverage from 26.000-32.000 MHz
Now reset the CPU by pressing the button below J2
To get a channel read out locate J1, the jumper will be on pins P1 and P2, move it to P2 and P3.
Now when you press the lock button you will toggle between CB channels and the VFO readout
 Post subject: Re: RCI-2950
PostPosted: Thu Oct 07, 2004 2:08 pm
There are three posts n the front of the radio that are shorted together to enble the "All Band" modofication. Just remove this and the radio should be configured as a 10 Mtr rig again.
Thank You,
Michael
ARS - KG7HQ
Assistant Director/Technical Specialist/VE
Northwestern Division
ARRL
kg7hq@arrl.net
http://www.kg7hq.wetnet.net
