It is currently Sun Sep 13, 2026 3:58 am
 Post subject: Firewall
PostPosted: Sun Jun 28, 2009 9:38 pm
Trying to get two power wires through my 2002 Toyota Sienna firewall. Any good ideas. My drill is at the ready. I have found no pop-outs and am a bit scared about the drill. Thanks.
-m
 Post subject: Re: Firewall
PostPosted: Sun Jun 28, 2009 11:09 pm
If you're near a library you can pull up the Chilton's or All Data online. Actually if you have a KCLS card you can pull up Chilton's online. KCLS and SPL.
PostPosted: Sun Jun 28, 2009 11:15 pm
Automatic Tranny or stick? I find on automatics the clutch popout plate is a good place usually.
PostPosted: Mon Jun 29, 2009 6:36 am
So when Sean says 'don't violate your firewall' why does it sound dirty. Thanks for the ideas. Off to find power on the fuse block.
PostPosted: Mon Jun 29, 2009 1:10 pm
or find another rubber boot and cut a small hole in it. never hole your firewall.
PostPosted: Mon Jun 29, 2009 9:54 pm
Ive been known to use a body plug next to the door hinges, and route into the fender on some cars. Usually when we mount a fender antenna.
Allot of broadcast radio antennas are routed this general direction also...
PostPosted: Mon Jun 29, 2009 10:09 pm
If I have no luck with the fuse block the fender is my next choice. Only thing this car does not have is rear DVD and that's where I'm going. Thanks.
PostPosted: Tue Jun 30, 2009 9:54 am
-m
I made a new hole in an existing grommet on my car and then sealed it up after snaking the cables through.
