It is currently Wed Sep 23, 2026 6:15 pm
 Post subject: ISS
PostPosted: Sun Mar 15, 2009 9:02 am
Made my first contact via ISS's repeater last night. THey make an number of passes over us on their swing around the earth.
145.8 out and 437.8 in. Don't forget the doppler effect (I don't know the effect, but it sure sounded good - right?)
 Post subject: Re: ISS
PostPosted: Sun Mar 15, 2009 10:12 am
:bowdown: K7SCN
PostPosted: Sun Mar 15, 2009 9:08 pm
Great fun. Contacted three stations this last pass.
-m
PostPosted: Thu Oct 01, 2009 5:57 pm
-m
I know this is a slightly older thread but.....what radio and antenna did you use to make the contact?
PostPosted: Fri Oct 02, 2009 9:14 pm
you can use any radio with full duplex (or two radios) from HT to multiple rigs, and a directional antenna AKA yagi
I have a IC7000 and use a scanner as the downlink radio, and a Elk MultiBand antenna.
PostPosted: Wed Oct 07, 2009 1:25 pm
You should be able to use the 7000 both up and down, correct?
PostPosted: Wed Oct 07, 2009 6:54 pm
well yes, but you need a uplink and downlink frequency, the IC7000 is half duplex and AFAIK you can only have one VFO at one time and RIT wont let you go that far off band (that I know of) mind you I think the 756 could if it did VHF but that only covers a bit, they also have U/V so if you had half duplex conversation
but dont quote me I dont get into the radio much I just simply use it for /p work. that's the reason for the scanner for the downlink rx I just can tell you it is NOT a full duplex radio for sat. work (including ISS which is a sat)
PostPosted: Thu Oct 08, 2009 1:30 pm
No, you should be able to set the downlink in VFO A and then the uplink in VFO B. Press the SPLIT function. I believe this will let you x-mit on the the VFO B frequency and then receive on VFO A.
I'll verify this later tonight, as I'm interpreting these steps from the 7000 manual online.
PostPosted: Thu Oct 08, 2009 1:43 pm
sounds good here that is the way the 756 works anywhoo, like I said I never bothered to learn the radio :)
http://www.issfanclub.com/
PostPosted: Fri Oct 09, 2009 12:56 pm
Thanks to SpudGunMan for the link. As a result I got to listen to the crew do an interview with an elementary school today in Langley, BC.
PostPosted: Fri Oct 09, 2009 6:18 pm
glad I could help, this was also timely to this thread
http://www.worldwidedx.com/general-ham- ... radio.html
 Post subject: Re: ISS 145.8
PostPosted: Sat Jan 31, 2015 8:39 pm
Just had a pass with some strange data with a very soft female ID every 30 seconds. Seems like it's been quiet for months.
PostPosted: Sat Jan 31, 2015 11:32 pm
It's SSTV.
PostPosted: Sat Jan 31, 2015 11:43 pm
Receiving a new pic now...
PostPosted: Sun Feb 01, 2015 4:01 am
How cool!
