It is currently Fri Sep 18, 2026 4:47 pm
PostPosted: Sat Dec 27, 2008 2:06 pm
Found this on the net and thought it should be passed along...
You Know You're a Ham if :
- you buy electrical black tape in ten packs.
- you've stripped wire with your teeth.
- you've told your son that, "One day, all this will be yours", and he doesn't respond.
- you'd rather help a buddy put up a new tower than mow the lawn.
- you've grabbed the wrong end of a soldering iron.
- you start giving out RST reports when you are on the telephone.
- the propagation forecast means far more to you than the local weather forecast.
- the microphone or visual aids at a meeting don't work and you rush up to the front to fix it.
- you tell the XYL, when she notices a new rig in the shack, why that has been there for years.
- your watch is set only to UTC.
- at night, when you pray, it starts off something like: CQ CQ CQ GOD DE (your callsign).
- you ever had to patch your roof after an antenna project.
- Ham radio magazines comprise more than 50% of your bathroom library.
- you ever put a GPS tracker in the XYL's car, just so you could watch her on APRS.
- you and the XYL took a cruise so you could visit the radio room.
- you ever tapped out HI in Morse on your car horn to another ham.
- you ever had an antenna fall down.
- your teenager refuses to ride in your car because it looks like a porcupine.
- you know the Latitude and Longitude of your home QTH.
- you go into the local Radio Shack store and the clerk asks you where something is.
