It is currently Sun May 10, 2026 10:54 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jul 19, 2015 9:19 pm
Here is a list of Fusion repeaters in Washington state
145.2100 +2.78 MHz D023 Mazama, Edelweiss Community Okanogan NO7RF
146.7600 -0.6 MHz 100.0 Port Angeles, Striped Peak Clallam W7FEL
442.7250 +5 MHz 100.0 Mill Creek Snohomish WR7DS
442.9750 +5 MHz 103.5 Snohomish, Clearview Snohomish WA7DEM
443.5250 +5 MHz Spokane Spokane WA7DRE
443.9000 +5 MHz 94.8 Vancouver, Larch Mountain Clark W7AIA
444.7250 +5 MHz 123.0 Edmonds Snohomish NW7DR
444.8500 +5 MHz D023 Winthrop, Horizon Flats Okanogan NO7RF
PostPosted: Sun Jul 19, 2015 9:40 pm
Someone wanna post some raw Fusion audio so I can remember it for future reference?
Second to last in Section 3:
http://www.w2sjw.com/radio_sounds.html
Gracias.
PostPosted: Sun Jul 19, 2015 10:13 pm
Just because they're listed doesn't mean they're actually active though. A sad fact. :(
PostPosted: Sun Jul 19, 2015 10:22 pm
I know that all are on the air in mixed mode at least except for Vancouver and Spokane. The repeater in Edmonds will do analog, D-STAR and Fusion.
PostPosted: Mon Jul 20, 2015 2:02 pm
443.9 is mixed mode active in Clark. Heard lots of fusioning going on the other day.
PostPosted: Tue Jul 21, 2015 11:13 am
Although we have fusion repeaters in the area, they are unfortunately not connect via IP/WIRES-X. I can speak for Clearview, Edmonds, Port Angeles and Mill Creek. NO7RF did have it connected but disconnected it to free up his 400. Apparently according to his website (http://www.trbo.org/fusion/wires-x.html), someone is making a TRBO-Fusion gateway. http://www.trbo.org/fusion/
PostPosted: Mon Jul 27, 2015 11:37 am
Just discovered that WA7LAW has a new Fusion Repeater operational at BakerView Apartments .444.575 + T103.5
Here is a list of Fusion WIRES-X systems on the air now from Yaesu web site. It doesn't give a list of frequencies unfortunately.
K7RFH Kent
WA7DRE Spokane
KB7APU Vancouver
KG7LAA Roslyn
KA7VEE Mount Vernon
KF7SDL Maple Valley
NE7IL Winthrop
KG7KPH Tacoma
KB7APU Vancouver
K7GJT Vancouver
NO7RF Winthrop
N7XLD Kirkland
PostPosted: Sat Aug 29, 2015 10:39 pm
Brad wrote:
n7ryy wrote:
So how do you like the FT-1D? On sale for $299 at HRO, was pondering one. Even if I hardly use it for digital I can eavesdrop :-)
For $299, it's not a bad radio. I just couldn't get past the volume control problem. That knob on top of the radio is used to change channels. It only becomes a volume control when you press and hold the "VOL" button on the side of the radio. Makes changing the radio volume a two handed operation. Not very convenient if you have the radio on your belt.
Also, several function that SHOULD be dedicated to front panel keys (like the TONE function) are buried in menus.
As Nick commented, there's not a lot of Fusion activity locally.
So, I sold my FT1-DR. I'll wait until Fusion matures a bit more before I try it again.
Brad.
You know Barry just got a FTM400 and ordered a Fusion rptr?
PostPosted: Sat Aug 29, 2015 11:33 pm
Yup. We talked about it at breakfast on Friday. He likes the radio - says the APRS function works well. He'll play with Fusion just to understand it.
He'll probably put the repeater up at Komo temporarily, just to try it out. For him, the allure of a $500 dual band repeater was too good to pass up.
PostPosted: Thu Nov 26, 2015 6:22 pm
Four more Fusion Systems:
Everett - 147.180, along with the 444.575 (Sponsored by the SnoHams club). Both are on Auto/Auto, 103.5 for analog side. The repeaters used to be linked together, but are now un-linked. Most users are trying to keep the Fusion noise on the UHF repeater.
Baldi - 147.220 (Sponsored by Rob/AF7PR). Due to an antenna issue, it's a bit deaf right now. 103.5 analog. It's co-channeled with the South Whidbey Island repeater (127.3)
Baldi - 440.075 (Sponsored by N7OEP). Workable from my house, and around Seattle. Also talked to a guy who was mobile in the Olympia area, and he was 100% digital copy. It's working well.
Soon to come:
Seattle - KOMO TV Tower repeater, 444.425, will be swapped out to a Fusion box in the next few weeks. Probably just an experiment for awhile.
Seattle - KCTS TV Tower, unknown what frequency. May be a permanent installation.
Brad/N7ER
PostPosted: Fri Jan 22, 2016 7:09 pm
Barry/K7PAL installed his Fusion repeater on the KOMO tower today. It replaced his Quantar P25 machine.
Good signal reports around Seattle.
Frequency 444.425. PL 141.3 for the analog side.
Unknown if this is a permanent change, or if the Fusion equipment will remain there permanently.
Brad.
