It is currently Sun Sep 20, 2026 2:35 pm
 Post subject: LVMPD Phase 2
PostPosted: Sun Feb 04, 2018 7:05 pm
Almost totally encrypted. There's some erroneous data that indicates clear traffic; dunno what the issue was.
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 5F6
System Name : LVMPD
WACN : BEE00
Tower Number (Decimal): 1-1
Tower Number (Hex) : T0101
Tower Description : Simo
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) : WQSF621
Timestamp : Fri Feb 2 14:38:22 2018
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-1136","i",769.10625,"01-1136",799.10625,0,0
"01-1408","d",770.80625,"01-1408",800.80625,0,0
"01-1442","d",771.01875,"01-1442",801.01875,0,0
"01-1466","d",771.16875,"01-1466",801.16875,0,0
"01-1508","a",771.43125,"01-1508",801.43125,0,0
"01-1532","ad",771.58125,"01-1532",801.58125,0,0
"01-1552","a",771.70625,"01-1552",801.70625,0,0
"01-1596","c",771.98125,"01-1596",801.98125,0,0
"03-1136","v",769.10625/0,"03-1136",769.10625/0,1,0
"03-1137","v",769.10625/1,"03-1137",799.10625/1,0,0
"03-1208","v",769.55625/0,"03-1208",769.55625/0,1,7
"03-1209","v",769.55625/1,"03-1209",769.55625/1,1,5
"03-1408","v",770.80625/0,"03-1408",770.80625/0,1,5
"03-1409","v",770.80625/1,"03-1409",800.80625/1,0,7
"03-1442","v",771.01875/0,"03-1442",801.01875/0,0,0
"03-1443","v",771.01875/1,"03-1443",801.01875/1,0,0
"03-1466","v",771.16875/0,"03-1466",801.16875/0,0,6
"03-1467","v",771.16875/1,"03-1467",801.16875/1,0,7
"03-1486","v",771.29375/0,"03-1486",771.29375/0,1,8
"03-1487","v",771.29375/1,"03-1487",801.29375/1,0,6
"03-1508","v",771.43125/0,"03-1508",771.43125/0,1,4
"03-1509","v",771.43125/1,"03-1509",771.43125/1,1,4
"03-1532","v",771.58125/0,"03-1532",771.58125/0,1,1
"03-1533","v",771.58125/1,"03-1533",771.58125/1,1,2
"03-1552","v",771.70625/0,"03-1552",771.70625/0,1,0
"03-1553","v",771.70625/1,"03-1553",771.70625/1,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
102,"T0102",5f6,"01-2066",774.91875,""
103,"T0103",5f6,"01-1758",772.99375,""
109,"T0109",5f6,"01-2038",774.74375,""
110,"T010A",5f6,"01-1538",771.61875,""
112,"T010C",5f6,"01-1614",772.09375,""
117,"T0111",5f6,"01-1542",771.64375,""
118,"T0112",5f6,"01-1618",772.11875,""
# Talkgroup List for this system
# Format: Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color,EncSeen,Hits,EmrgIgnore
# Priority Values: 0=Ignore, 1=Highest priority, 99= Lowest Priority
10001,50,"T: 101 DT: 2/2/18@13:58",1517608715,"02/02/2018 @ 13:58",1517608715,"02/02/2018 @ 13:58","#000000","#000000","N",0,1
10002,50,"T: 101 DT: 2/2/18@14:27",1517610434,"02/02/2018 @ 14:27",1517610434,"02/02/2018 @ 14:27","#000000","#000000","N",0,1
10003,50,"T: 101 DT: 2/2/18@13:52",1517608362,"02/02/2018 @ 13:52",1517608362,"02/02/2018 @ 13:52","#000000","#000000","N",0,1
10004,50,"T: 101 DT: 2/2/18@13:52",1517608338,"02/02/2018 @ 13:52",1517608338,"02/02/2018 @ 13:52","#000000","#000000","N",0,1
10005,50,"T: 101 DT: 2/2/18@13:52",1517608346,"02/02/2018 @ 13:52",1517608346,"02/02/2018 @ 13:52","#000000","#000000","N",0,1
10006,50,"T: 101 DT: 2/2/18@13:52",1517608327,"02/02/2018 @ 13:52",1517608327,"02/02/2018 @ 13:52","#000000","#000000","N",0,1
10007,50,"T: 101 DT: 2/2/18@14:00",1517608833,"02/02/2018 @ 14:00",1517608833,"02/02/2018 @ 14:00","#000000","#000000","N",0,1
10008,50,"T: 101 DT: 2/2/18@13:57",1517608624,"02/02/2018 @ 13:57",1517608624,"02/02/2018 @ 13:57","#000000","#000000","N",0,1
10009,50,"T: 101 DT: 2/2/18@13:52",1517611087,"02/02/2018 @ 14:38",1517608327,"02/02/2018 @ 13:52","#000000","#000000","N",66,1
10010,50,"T: 101 DT: 2/2/18@13:51",1517611102,"02/02/2018 @ 14:38",1517608309,"02/02/2018 @ 13:51","#000000","#000000","N",93,1
10011,50,"T: 101 DT: 2/2/18@14:00",1517608839,"02/02/2018 @ 14:00",1517608839,"02/02/2018 @ 14:00","#000000","#000000","N",0,1
10017,50,"T: 101 DT: 2/2/18@14:31",1517610683,"02/02/2018 @ 14:31",1517610683,"02/02/2018 @ 14:31","#000000","#000000","N",0,1
10037,50,"T: 101 DT: 2/2/18@13:56",1517608606,"02/02/2018 @ 13:56",1517608606,"02/02/2018 @ 13:56","#000000","#000000","N",0,1
10045,50,"T: 101 DT: 2/2/18@14:09",1517609345,"02/02/2018 @ 14:09",1517609345,"02/02/2018 @ 14:09","#000000","#000000","N",0,1
10067,50,"T: 101 DT: 2/2/18@14:22",1517610131,"02/02/2018 @ 14:22",1517610131,"02/02/2018 @ 14:22","#000000","#000000","N",0,1
10088,50,"T: 101 DT: 2/2/18@13:53",1517608430,"02/02/2018 @ 13:53",1517608430,"02/02/2018 @ 13:53","#000000","#000000","N",0,1
10098,50,"T: 101 DT: 2/2/18@13:57",1517608638,"02/02/2018 @ 13:57",1517608638,"02/02/2018 @ 13:57","#000000","#000000","N",0,1
10109,50,"T: 101 DT: 2/2/18@13:54",1517611082,"02/02/2018 @ 14:38",1517608448,"02/02/2018 @ 13:54","#000000","#000000","N",33,1
10113,50,"T: 101 DT: 2/2/18@13:59",1517609604,"02/02/2018 @ 14:13",1517608775,"02/02/2018 @ 13:59","#000000","#000000","N",1,1
10115,50,"T: 101 DT: 2/2/18@14:22",1517610163,"02/02/2018 @ 14:22",1517610163,"02/02/2018 @ 14:22","#000000","#000000","N",0,1
10116,50,"T: 101 DT: 2/2/18@14:22",1517610165,"02/02/2018 @ 14:22",1517610165,"02/02/2018 @ 14:22","#000000","#000000","N",0,1
10117,50,"T: 101 DT: 2/2/18@14:22",1517610166,"02/02/2018 @ 14:22",1517610166,"02/02/2018 @ 14:22","#000000","#000000","N",0,1
10120,50,"T: 101 DT: 2/2/18@13:52",1517610601,"02/02/2018 @ 14:30",1517608355,"02/02/2018 @ 13:52","#000000","#000000","N",3,1
10123,50,"T: 101 DT: 2/2/18@14:01",1517608899,"02/02/2018 @ 14:01",1517608899,"02/02/2018 @ 14:01","#000000","#000000","N",0,1
10340,50,"T: 101 DT: 2/2/18@13:57",1517608640,"02/02/2018 @ 13:57",1517608640,"02/02/2018 @ 13:57","#000000","#000000","N",0,1
20039,50,"T: 101 DT: 2/2/18@14:15",1517609738,"02/02/2018 @ 14:15",1517609738,"02/02/2018 @ 14:15","#000000","#000000","N",0,1
20040,50,"T: 101 DT: 2/2/18@13:54",1517609418,"02/02/2018 @ 14:10",1517608462,"02/02/2018 @ 13:54","#000000","#000000","Y",60,1
20051,50,"T: 101 DT: 2/2/18@14:02",1517609403,"02/02/2018 @ 14:10",1517608974,"02/02/2018 @ 14:02","#000000","#000000","Y",16,1
20057,50,"T: 101 DT: 2/2/18@13:52",1517611039,"02/02/2018 @ 14:37",1517608335,"02/02/2018 @ 13:52","#000000","#000000","Y",120,1
20058,50,"T: 101 DT: 2/2/18@14:14",1517609648,"02/02/2018 @ 14:14",1517609648,"02/02/2018 @ 14:14","#000000","#000000","N",0,1
20059,50,"T: 101 DT: 2/2/18@13:54",1517608460,"02/02/2018 @ 13:54",1517608460,"02/02/2018 @ 13:54","#000000","#000000","N",0,1
20060,50,"T: 101 DT: 2/2/18@13:53",1517608398,"02/02/2018 @ 13:53",1517608398,"02/02/2018 @ 13:53","#000000","#000000","N",0,1
20065,50,"T: 101 DT: 2/2/18@14:06",1517609163,"02/02/2018 @ 14:06",1517609163,"02/02/2018 @ 14:06","#000000","#000000","N",0,1
20067,50,"T: 101 DT: 2/2/18@13:55",1517608525,"02/02/2018 @ 13:55",1517608525,"02/02/2018 @ 13:55","#000000","#000000","N",0,1
20071,50,"T: 101 DT: 2/2/18@13:51",1517611100,"02/02/2018 @ 14:38",1517608309,"02/02/2018 @ 13:51","#000000","#000000","Y",85,1
20080,50,"T: 101 DT: 2/2/18@13:55",1517611102,"02/02/2018 @ 14:38",1517608510,"02/02/2018 @ 13:55","#000000","#000000","Y",82,1
20086,50,"T: 101 DT: 2/2/18@14:21",1517610069,"02/02/2018 @ 14:21",1517610069,"02/02/2018 @ 14:21","#000000","#000000","N",0,1
20087,50,"T: 101 DT: 2/2/18@14:20",1517610057,"02/02/2018 @ 14:20",1517610057,"02/02/2018 @ 14:20","#000000","#000000","N",0,1
20088,50,"T: 101 DT: 2/2/18@13:57",1517608653,"02/02/2018 @ 13:57",1517608653,"02/02/2018 @ 13:57","#000000","#000000","N",0,1
20103,50,"T: 101 DT: 2/2/18@14:01",1517611096,"02/02/2018 @ 14:38",1517608889,"02/02/2018 @ 14:01","#000000","#000000","Y",26,1
20104,50,"T: 101 DT: 2/2/18@13:55",1517608518,"02/02/2018 @ 13:55",1517608518,"02/02/2018 @ 13:55","#000000","#000000","N",0,1
20115,50,"T: 101 DT: 2/2/18@13:52",1517608350,"02/02/2018 @ 13:52",1517608350,"02/02/2018 @ 13:52","#000000","#000000","N",0,1
20124,50,"T: 101 DT: 2/2/18@14:22",1517610172,"02/02/2018 @ 14:22",1517610172,"02/02/2018 @ 14:22","#000000","#000000","N",0,1
20130,50,"T: 101 DT: 2/2/18@13:51",1517611102,"02/02/2018 @ 14:38",1517608309,"02/02/2018 @ 13:51","#000000","#000000","Y",95,1
20131,50,"T: 101 DT: 2/2/18@13:54",1517611095,"02/02/2018 @ 14:38",1517608483,"02/02/2018 @ 13:54","#000000","#000000","Y",22,1
20132,50,"T: 101 DT: 2/2/18@13:51",1517611102,"02/02/2018 @ 14:38",1517608309,"02/02/2018 @ 13:51","#000000","#000000","Y",140,1
20133,50,"T: 101 DT: 2/2/18@13:52",1517611064,"02/02/2018 @ 14:37",1517608330,"02/02/2018 @ 13:52","#000000","#000000","Y",87,1
20134,50,"T: 101 DT: 2/2/18@13:51",1517611041,"02/02/2018 @ 14:37",1517608309,"02/02/2018 @ 13:51","#000000","#000000","Y",86,1
20135,50,"T: 101 DT: 2/2/18@13:51",1517611097,"02/02/2018 @ 14:38",1517608309,"02/02/2018 @ 13:51","#000000","#000000","Y",121,1
20136,50,"T: 101 DT: 2/2/18@14:03",1517608981,"02/02/2018 @ 14:03",1517608981,"02/02/2018 @ 14:03","#000000","#000000","N",0,1
20138,50,"T: 101 DT: 2/2/18@14:03",1517609034,"02/02/2018 @ 14:03",1517609034,"02/02/2018 @ 14:03","#000000","#000000","N",0,1
20141,50,"T: 101 DT: 2/2/18@14:03",1517609039,"02/02/2018 @ 14:03",1517609039,"02/02/2018 @ 14:03","#000000","#000000","N",0,1
20142,50,"T: 101 DT: 2/2/18@14:03",1517609001,"02/02/2018 @ 14:03",1517609001,"02/02/2018 @ 14:03","#000000","#000000","N",0,1
20152,50,"T: 101 DT: 2/2/18@13:51",1517611044,"02/02/2018 @ 14:37",1517608309,"02/02/2018 @ 13:51","#000000","#000000","Y",74,1
20153,50,"T: 101 DT: 2/2/18@13:52",1517611090,"02/02/2018 @ 14:38",1517608323,"02/02/2018 @ 13:52","#000000","#000000","Y",99,1
20154,50,"T: 101 DT: 2/2/18@13:51",1517610968,"02/02/2018 @ 14:36",1517608310,"02/02/2018 @ 13:51","#000000","#000000","Y",66,1
20156,50,"T: 101 DT: 2/2/18@13:52",1517611102,"02/02/2018 @ 14:38",1517608328,"02/02/2018 @ 13:52","#000000","#000000","Y",114,1
20157,50,"T: 101 DT: 2/2/18@13:51",1517611101,"02/02/2018 @ 14:38",1517608309,"02/02/2018 @ 13:51","#000000","#000000","Y",128,1
20169,50,"T: 101 DT: 2/2/18@13:52",1517611087,"02/02/2018 @ 14:38",1517608334,"02/02/2018 @ 13:52","#000000","#000000","Y",68,1
20186,50,"T: 101 DT: 2/2/18@13:54",1517609335,"02/02/2018 @ 14:08",1517608458,"02/02/2018 @ 13:54","#000000","#000000","Y",11,1
20402,50,"T: 101 DT: 2/2/18@13:54",1517608484,"02/02/2018 @ 13:54",1517608484,"02/02/2018 @ 13:54","#000000","#000000","N",0,1
20403,50,"T: 101 DT: 2/2/18@13:51",1517611102,"02/02/2018 @ 14:38",1517608309,"02/02/2018 @ 13:51","#000000","#000000","Y",81,1
20404,50,"T: 101 DT: 2/2/18@13:51",1517610963,"02/02/2018 @ 14:36",1517608315,"02/02/2018 @ 13:51","#000000","#000000","Y",29,1
20407,50,"T: 101 DT: 2/2/18@13:54",1517611082,"02/02/2018 @ 14:38",1517608448,"02/02/2018 @ 13:54","#000000","#000000","Y",33,1
20411,50,"T: 101 DT: 2/2/18@14:00",1517609095,"02/02/2018 @ 14:04",1517608850,"02/02/2018 @ 14:00","#000000","#000000","Y",6,1
