It is currently Sun Sep 13, 2026 3:49 am
 Post subject: Pasco WA KPSC TSA
PostPosted: Thu Jul 03, 2025 4:42 pm
As a side benefit of staying at the airport in Pasco, I finally managed to catch the TSA at Pasco, WA (KPSC).
They are on 411.2875, $198. All ENC so far and RIDs are 997xxx.
It's a typical small airport, but it is served by 4 airlines with about 10 flights a day.
Only one security checkpoint, but they do have TSA Pre!
The frequency is not very busy but I sat inside next to the check point for a while had a beverage. It payed off…
- CP
Chris Parris
Federal Wavelengths columnist
The Spectrum Monitor Magazine
chrisparris@thefedfiles.com
 Post subject: Re: Pasco WA KPSC TSA
PostPosted: Mon Jul 07, 2025 5:33 am
the lengths we go thru, to find a target.
- CP
PostPosted: Mon Jul 07, 2025 3:28 pm
Seems there's been some discussion on that around the web recently...
PostPosted: Tue Jul 08, 2025 9:06 pm
and the backstories that will never see the light of day.
PostPosted: Tue Jul 15, 2025 4:26 am
like being handed a radio and not having your SW and Cables. so you take a Steno pad and
Write each Zone/Channel/Alpha on each page, then set-up your Close-Call to (quick key) and capture the TX
then Repeat (note - this was before CC also handled PL/DPL - older scanners) putting in each freq to get the NAC/PL
then as the battery (o yea, he forgot to give me a charger) was getting low, found out it would do Low Power
and repeated each (48+ zones) each on simplex to get the output freq
Long Night and Cold Beers and statute of limitations has expired
