It is currently Wed Sep 09, 2026 11:53 am
 Post subject: WA DOC- Coyote Ridge
PostPosted: Sun Jun 01, 2025 2:23 pm
Coyote Ridge Wiki link to dispel interest in URLs...
https://wireless2.fcc.gov/UlsApp/UlsSea ... ey=3822495
https://wireless2.fcc.gov/UlsApp/UlsSea ... ey=3827488
Noted Bunnist TMF was dispatched to recon this system in Operation Odin. His report (via text) follows:
Control channel on 856.5125
NAC of $C71
TGIDs noted:
100
101
103
105
The lack of a SysID (which means Nicky can't submit to RR) will be corrected in the near future with a complete Pro96Com track of the system (tentatively named Operation Hercules).
 Post subject: Re: WA DOC- Coyote Ridge
PostPosted: Fri Jun 06, 2025 5:14 am
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : C7F
System Name : WASHINGTON DOC
WACN : BEE00
Tower Number (Decimal): 1-1
Tower Number (Hex) : T0101
Tower Description : COYOTE RIDGE
Control Capabilities : Voice,Registration
Flavor : Phase 2
Call Sign(s) :
Timestamp : Thu Jun 5 11:01:05 2025
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0169","c",852.06250,"00-0169",807.06250,0,0
"00-0281","a",852.76250,"00-0281",807.76250,0,0
"00-0341","a",853.13750,"00-0341",808.13750,0,0
"00-0593","av",854.71250,"00-0593",809.71250,0,6
"00-0881","v",856.51250,"00-0881",811.51250,0,36
PostPosted: Wed Jun 11, 2025 3:46 pm
FileVersion:7
# Talkgroup List for this system
# Format: Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color,EncSeen,Hits,EmrgIgnore
# Priority Values: 0=Ignore, 1=Highest priority, 99= Lowest Priority
100,50,"T: 101 DT: 6/5/25@10:44",1749146430,"06/05/2025 @ 11:00",1749145496,"06/05/2025 @ 10:44","#000000","#000000","N",16,1
101,50,"T: 101 DT: 6/5/25@10:45",1749146322,"06/05/2025 @ 10:58",1749145511,"06/05/2025 @ 10:45","#000000","#000000","N",15,1
103,50,"T: 101 DT: 6/5/25@10:45",1749146428,"06/05/2025 @ 11:00",1749145531,"06/05/2025 @ 10:45","#000000","#000000","N",9,1
105,50,"T: 101 DT: 6/5/25@10:56",1749146207,"06/05/2025 @ 10:56",1749146180,"06/05/2025 @ 10:56","#000000","#000000","N",2,1
107,50,"T: 101 DT: 6/5/25@10:46",1749145595,"06/05/2025 @ 10:46",1749145595,"06/05/2025 @ 10:46","#000000","#000000","N",0,1
111,50,"T: 101 DT: 6/5/25@10:46",1749145593,"06/05/2025 @ 10:46",1749145593,"06/05/2025 @ 10:46","#000000","#000000","N",0,0
PostPosted: Thu Jun 12, 2025 9:43 am
You must have a great antenna Wil !!!
A TMF highgain :)
