It is currently Mon Sep 14, 2026 8:07 pm
PostPosted: Wed Mar 15, 2017 10:42 am
Hoping someone can help me figure this one out....
I have both a TRX-1 and a BCD436.
The TRX-1 is picking up WSP (Washington State Patrol) - the 436 not so much.
This is on the (now narrowbanded/digital) conventional VHF 154-158 freqs.
JIWN (Justice Integrated Wireless Network - trunked VHF) and WSPDOT (WA State Patrol Dept of Transp - trunked 700) seem to be working fine.
These scanners were both programmed via RR database.
Both are using a Diamond RH77, so antennas are the same
I did notice the TRX-1 had FM programmed on the P25/digital freqs (via RR), the 436 had NFM programmed via RR. I changed the 436 where needed to FM on these.
Still hearing nothing.
And yes, it is scanning them freqs, just not hearing anything.
I even turned location off, just in case that was the problem.
Nope...
Any suggestions??
Thanks
PostPosted: Wed Mar 15, 2017 3:26 pm
...and why are you asking on this forum and not the RR folks?
PostPosted: Wed Mar 15, 2017 9:50 pm
He's looking for accurate information?
PostPosted: Wed Mar 15, 2017 10:00 pm
Uniden. Enough said.
JIWN is actually IWN, and WSPDOT is just WSP. IWN dropped the J a few years ago, and WSPDOT is someone's imaginary name. WSDOT has their own 800 system and is working feverishly on a 700 Phase-2 system.
Not knowing anything about the RR 'database', I'll first ask what NAC codes are programmed in? Then we'll discuss preset squelch settings, etc.
As an aside, on my TRX radios I use NFM or AUTO only (though I don't listen to WSP...or WSDOT).
PostPosted: Wed Mar 15, 2017 10:02 pm
He's definitely come to the wrong place then...
PostPosted: Wed Mar 22, 2017 9:48 pm
Set the NAC to F7E and see if that makes a difference, if the scanner even supports it...
PostPosted: Thu Mar 23, 2017 5:20 pm
UNIDEN IZ BEST EVR FER TRAKKIN BEaRZ
Feverish? I doubt that, we are talking about the state right???
Users browsing this forum: No registered users and 96 guests
