It is currently Sun May 03, 2026 6:10 pm
PostPosted: Sat Jun 11, 2016 11:29 am
452.65 (Active but strong signal (3 bars))
451.825 (Active but weak signal (1 bar))
452.275 (Active strong signal (3-4 bars))
452.7 (Active seems strongest today (4 bars))
***Comms are up -- same frequencies as last year... here's what was listed last year... looks to be same format***
University of Washington @ Husky Stadium
40w output with antennas on top of Graves building.
http://wireless2.fcc.gov/UlsApp/UlsSear ... ey=3526844
Commencement communications! Very chatty as expected. Sounds like they're not entirely happy with digital radio! (A lot of repeats!) :)
TGIDs:
1 SLOT 1 (Focused on security, first aid, seating ushers, supervisors)
1 SLOT 2 (Focused on the actual graduation movements, which group is walking, monitoring time)
RGIDs:
18141 Kelly (also under FiC)
18809 Cisco (Usher)
18816
18876 Jackie
18902
18948 Sarah
18975 Dan
19025 COMMAND (Dan)
20099
24906
25377
25379 Molly
25407
25416 Jess
25697 Cody
26201
26226 Frank (club husky)
26312 Lisa
27274
27308 Female (Cindy) under FiC (feel sorry for her)
27564
27657
27695 John
27838 Brian
27864 Ed
27873 **Female (Sean?) in charge of grad movements dishing out orders/directions
28020 Guest Services
PostPosted: Sat Jun 11, 2016 12:37 pm
Called it.
PostPosted: Sat Jun 11, 2016 1:05 pm
All "conventional"? Color codes?
452.7 is also one of the TRBOWest channels on Capitol; I bet you can pick that up from your QTH as well.
452.65 I've seen but haven't pegged its users; CC1 with TG1 on both slots; mostly everyone is RID 1 with 4062450 popping occasionally. Looks a bit higher than the range you're seeing.
PostPosted: Sat Jun 11, 2016 1:38 pm
Yes, Tim, I'm getting the TRBOWEST channel at times too but fortunately, it's not very active.
I don't know what's going on with this system. I'm almost thinking each frequency is a separate system despite the same TGID and RIDs. The funny thing is that I'm hearing multiple voices on the same RID. Whomever designed this system should be shot -- it's very confusing to monitor. My gut says these are all separate systems -- and they're not connected.
i.e. basically someone set them up to be analog-like using a repeater, the same RID and TGID.
It also doesn't make much sense why certain frequencies are weaker than others. I guess the repeater antennas could be directional?
PostPosted: Sat Jun 11, 2016 1:47 pm
That wouldn't surprise me at all; UW's Transportation Services and Campus Engineering & Operations each have a freq (simulcast) and use two slots on each. But they both have all talkgroups programmed in to one radio. Makes writing the template a lot easier even though they probably don't ever need to talk to each other.
Or became directional based on how they got mounted at the stadium?
PostPosted: Sat Jun 11, 2016 1:54 pm
Yep that's what I was thinking. Someone made a generic template and didn't bother making specifics. They could program each radio with the same template but use different channels for the frequencies.
It'd be funny if UW-Husky Stadium was using the TYT MD-380 as their portable radio! xD
