It is currently Mon Mar 02, 2026 9:16 am
 Post subject: Wildfires
PostPosted: Mon May 16, 2016 10:57 am
Lots of traffic the past few days from the fires near Oso and Goldbar. DNR Northwest channels are active, but from my location I couldn't figure out any pattern of which was Command etc. or what the tac and common freqs were used for.
Heard SnoHawk on the 800 system, apparently with no VHF FM comms to the ground attack teams since their ground contact was relaying for them, and was trying to run a 800 portable out to the fire line. VTAC11 was in use as an air-ground channel. Anyone hear any AM traffic?
 Post subject: Re: Wildfires
PostPosted: Mon May 16, 2016 12:26 pm
Make sure you have the new SNO CALL in your scanner. There's a joint command being run on that.
