It is currently Sat May 16, 2026 5:31 pm
Post new topic Reply to topic  [ 70 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: WSP TRS Changeover
PostPosted: Tue Dec 02, 2014 8:03 am
Looks like starting today WSP will be switching over to their Phase 2 700MHz trunking and P25 for their VHF in south area of King County. Next week they will start switching the north King County area over to TRS and digital. I wonder if they are going to simulcast on both VHF & TRS for awhile.
 Post subject: Re: WSP TRS Changeover
PostPosted: Tue Dec 02, 2014 10:32 am
Confirmed. Hearing TGID 59210 currently on Phase 2. I haven't heard anything on 154.68 as yet. I wonder if they moved to Phase 2 only for now..?
TGID 59203 must be their Car-2-Car channel. One unit just asked a buddy how his voice sounds. "Does my voice sound like a 1980's Microsoft computer?"
TGID 59209 is active. No idea what it is yet.
I have to agree with the audio quality. It's very muddled at times. Some units are very clear and others sound like they're under water and speaking Swahili.
PostPosted: Tue Dec 02, 2014 11:40 am
That's because WSP thought they knew better in the vocoder and DSP settings than the defaults that came from Motorola. I remember they had the same issues when they were on P25 in Tacoma.
PostPosted: Tue Dec 02, 2014 5:01 pm
Just heard WSP Seattle South doing some dispatching on State (155.970), analog.
PostPosted: Wed Dec 03, 2014 10:22 am
I'm hearing that 154.680 went to P25 this morning.
PostPosted: Wed Dec 03, 2014 10:28 am
I happened to check around 3am and 154.68 was on P25 but not hearing P25 as of right now. Looks like they're still fighting the digital gremlins.
PostPosted: Wed Dec 03, 2014 12:34 pm
So is the plan to switch all of WSP to 700mhz and go away from VHF or just certain areas.
PostPosted: Wed Dec 03, 2014 12:49 pm
I’m hearing WSP will simulcast into the foreseeable feature... But as always, especially with government, it's subject to change at any time.
PostPosted: Wed Dec 03, 2014 1:24 pm
Here's a quick example of the Phase 2 audio quality. It would really help if the dispatchers learned to slow down their speech a bit. I'm sure this will go over well with them. :)
http://home.comcast.net/~k7cj/wsp700a.mp3
This is while using an external antenna too... signal quality is not a factor here...
PS. I am hearing P25 on 154.68 VHF now...
PostPosted: Wed Dec 03, 2014 3:41 pm
I hear oodles of packet loss in that recording; Phase-2 should sound way better than that, even with the dispatcher not articulating enough for the vocoder.
Just as a footnote... If you recorded that off 700 MHz, according to what the forums say, you are correct that it's Phase-2. If on VHF, I can say with certainty that it's Phase-1 (because I'm monitoring with Phase-1 only capable radios). When yours does come in clearly, yours sounds better than what I'm hearing on VHF.
PostPosted: Wed Dec 03, 2014 3:54 pm
Yes that's from the PSR-800 from Phase 2. Yesterday, I sniffed it with Pro96com and it's definitely TDMA.
I'm having a hard time picking up the P25 on VHF. It barely breaks the squelch on my XTS5000 and the 396XT can't even pick it up which is very strange. I can hear it fine on the V71 so not sure why the decode is off. Perhaps they're still tweaking the P25 VHF system.
PostPosted: Wed Dec 03, 2014 3:56 pm
I think the WSP dispatchers are just trained to be super-efficient with their speech and most talk very fast. I don't think the vocoder is able to keep up when they get in that mumble-zone where they talk a bit too fast and at the same tone.
PostPosted: Wed Dec 03, 2014 7:30 pm
The packet loss your hearing is probably from the PSR-800 decoding. If you had a Motorola, I think you would hear things differently.
A control channel is needed for Phase 2. Since VHF is all conventional with WSP, all traffic will be in Phase 1. Also, just because you have a TRS that is capable with Phase 2, doesn't mean it is always in Phase 2. Phase 2 TRS are backwards compatible with Phase 1 radios. So lets say a subscriber who has a phase 1 radio (XTS5000) and keys up or even logs onto a TG meant for Phase 2, the channel and/or frequency will go from Phase 2 (TDMA) to Phase 1 (FDMA).
PostPosted: Thu Dec 04, 2014 5:31 am
I'm not so sure on that. I have similar recordings where the parties sound really good. If the PSR-800 was at fault, then I think I'd hear consistently poor audio quality.
PostPosted: Thu Dec 04, 2014 6:19 am
My APX is decoding it perfectly.
