It is currently Wed May 27, 2026 2:18 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
PostPosted: Mon Sep 09, 2013 11:03 pm
206 SW 112th ST, Seattle (WQRL631)
769.30625
769.80625
770.30625
770.80625
773.20625
773.70625
774.20625
774.70625
HOFFMAN Hill, Dupont (WQRK643)
17908 16th ST, Home (WQRK643)
17128 80th ST, Vaughn (WQRK643)
TACOMA NARROWS BRIDGE SUPPORT STRUCTURE, Tacoma (WQRK643)
773.43125
773.68125
773.93125
774.18125
774.43125
774.68125
WATER WORKS RD, KING/PIERCE COUNTY LINE, Tacoma (WQPZ542)
773.60625
WATER TANK, Dupont (WQPZ542)
773.10625
SPAR POLE HILL, Orting (WQPZ542)
773.75625
7.5M SE, Buckley (WQPZ542)
773.25625
25016 Meridian St, Graham (WQPZ542)
773.85625
774.00625
SPAR POLE HILL, Orting (WQPM841)
4812 196th ST E, Spanaway (WQPM841)
769.33125
769.58125
769.85625
770.10625
770.35625
770.60625
770.85625
771.78125
773.45625
773.98125
774.48125
774.73125
PostPosted: Sun Sep 15, 2013 2:48 pm
Dude
Phase II = TDMA
PostPosted: Sun Sep 15, 2013 7:04 pm
How does a talkgroup = a modulation scheme?
(hint, it does not)
PostPosted: Tue Sep 17, 2013 8:48 pm
Pimp Daddy Radio
(hint, it does not)
Can't believe I'm saying this, but he actually does have a valid point.
Phase II systems can operate in phase I if even one radio affiliated to a specific talkgroup isn't TDMA capable.
PostPosted: Wed Sep 18, 2013 9:16 am
So then what does this mean:
Unfortunately, Phase 2 is not backwards compatible with Phase 1 (due to the TDMA vs FDMA operation). This will make analog narrow-band FM the defacto "interoperability" mode for some time.
I think it just depends on if the system is truly Phase 2 or a Phase 1 + Phase 2 implementation.
PostPosted: Wed Sep 18, 2013 10:20 am
The system will allow a phase I radio to affiliate as Phase I and then drag a Phase II talkgroup down to Phase I.
PostPosted: Sat Sep 28, 2013 7:31 pm
So if you have a PSR6 or a 396 you'll get to hear the sounds of encrypted comms
PostPosted: Sat Sep 28, 2013 8:47 pm
Depends on how the system is set up.
Most of the systems I know, will have a separate FDMA and TDMA TGs, the FDMA tallkgroups aren't active until an FDMA radio affiliates, normally.
PostPosted: Sun Jun 15, 2014 3:55 pm
Getting some light traffic on this system as of today. TGID 7 is active. Sounds like the primary PCT dispatch channel.
I'm listening on my 536HP but haven't confirmed it's Phase 2. It sounds like it but am trying to confirm somehow...
UPDATE: My PSR800 says it's still in P25 Phase 1 mode.
PostPosted: Wed Jun 18, 2014 3:47 pm
Here's the updated system so far:
Code:
Last updated 6/18/2014
PIERCE COUNTY P25 PHASE 2 PROJECT (SOUTH SOUND 911)
PIERCE TRANSIT
SYSTEM ID: 1E7
**CURRENTLY IN PHASE 1 P25 MODE**
ACTIVE SYSTEMS:
1-01   1E7   774.68125   WQRK643   (Tacoma) Central Pierce
1-02   1E7   774.48125   WQPM841   (Orting) SE Pierce
1-03   1E7   773.73125   WQPM835   (Mineral) South Pierce (Mt Rainier)
1-04   1E7   774.70625   WQRL631   (West Seattle) South King County
1-05   1E7   773.48125   WQPM839   (Buckley) East Pierce
Site 102 (Orting)
774.48125   control
770.35625   alternate
770.60625   alternate
773.98125   alternate
771.78125   data
773.45625   data
774.73125   data
Site 104 (West Seattle)
774.70625   control
774.20625   alternate
773.20625   alternate + data
769.80625   voice + data
773.70625   voice + data
770.30625   identifier (cw) CHANGEME
769.30625   identifier
TGIDs
3   PCT Dispatch
5   PCT Dispatch
7   PCT Dispatch
9   PCT Dispatch
17  PCT "Seattle Supervisor"
PostPosted: Tue Jun 24, 2014 4:12 pm
Uh....Phase II requires the implementation of Phase I in the radios due the fact that there is no phase II for simplex operations; it needs a timing reference so phase I still works...
PostPosted: Sun Jul 06, 2014 1:46 pm
http://www.soundtransit.org/Documents/pdf ... M2014-30.pdf
PostPosted: Fri Oct 17, 2014 9:04 pm
Announcement: it appears that PCSO is now on the new system and are using Phase II P25 talkgroups.
PostPosted: Sun Oct 19, 2014 11:25 am
I know that several smaller county fire dept have radio's delivered and installs are to be coming soon.
PostPosted: Wed Oct 22, 2014 3:25 pm
NVM.
