It is currently Wed May 13, 2026 3:41 am
PostPosted: Thu Jun 20, 2013 1:01 am
Here's my list so far:
Code:
DMR from my QTH:
452.075
452.275      **Active VOICE
452.3        **Part-time DMR?  Some other data mode shares this frequency, higher-pitched
452.7
454.3875
454.425
454.475
460.675
461.4375
461.5375
461.8
461.825      **Active VOICE
461.9625?
462.0875
463.15
463.2
463.4125
463.5        **Active VOICE
463.6125     **Active VOICE
464.275
464.8125
464.875
464.925      **Active VOICE
By "Active VOICE" means that DSD is decoding it as TRBO
PostPosted: Fri Jun 21, 2013 7:42 pm
452.3875 The Bravern in Downtown Bellevue
Getting fair reception using DSD as they are TRBO. Frequency sounds more like a general channel -- security, concierge-like services
PostPosted: Fri Jun 21, 2013 7:55 pm
464.925 Virginia Mason Medical Center on East Hill, Seattle
Strong signal and good decodes. A couple of docs making bad jokes.
PostPosted: Fri Jun 21, 2013 8:55 pm
Hi are using this on windows or some other OS ? DSD works great on the provoice for me have not been able to get it to work on trbo . I am using windows .
PostPosted: Fri Jun 21, 2013 9:48 pm
Win7-64 and DSD 1.60
What scanner do you have? It needs a discrimator-tap output for best decodes...
PostPosted: Sat Jun 22, 2013 4:01 pm
PSR 800
PostPosted: Sat Jun 22, 2013 5:23 pm
Ah okay. I forgot to try my PSR800 with its disc output. I think I tried it before and had flakey results -- but will try it again tonight.
UPDATE: PSR800 is very flakey with IF out -- at least for me. I couldn't get any decodes. DSD acts very weird using PSR800.
I've heard some people say that DSD *requires* a resistor inline for any discriminator output, so I guess it's possible the raw output from the PSR800 is causing weird side effects with DSD.
I have a R/S Pro-2006 and BCT-15 with discriminator taps. They both seem to decode very well.
Example of BCT-15 tap: http://www.discriminator.nl/ubc800xlt/index-en.html
PostPosted: Sat Jun 22, 2013 7:56 pm
460.675 Frontier Airlines at SeaTac Airport
Good signal and clean decodes. Sounds like the usual handlers, agents, roving CS people, supervisors, etc.
PostPosted: Sun Jun 23, 2013 3:58 pm
Thanks Nick
PostPosted: Sun Jun 23, 2013 4:07 pm
mw wrote:
Thanks Nick
FYI, I spotted this late last night. Per the Yahoo group the PSR-800 is very touchy with DSD. So in the PSR-800 software there's an IF level (volume level) adjustment. I turned mine down from MAX to 20 (scale of 30) and it seemed to be less touchy.
A couple of users suggested force DMR mode only. I still haven't heard any voice decode with the PSR-800 but it's much better overall.
I'll keep playing with it. It would be nice to have a portable solution for DSD.
