It is currently Sat Jan 31, 2026 6:54 am
 Post subject: Kent Records
PostPosted: Thu May 19, 2005 7:39 pm
Lately I have heard a new reference to "Records" within the Kent Police Trunk Group. What might be the TrunkID for this new "channel"?
Jim
KA7GZR
PostPosted: Fri May 20, 2005 8:28 am
Jim I also listen to KENT PD I'M BLK over from them but I haven't heard that yet, I will keep listening and see what I can come up with!
PS: did you once have the 442.950 r?
STEVE F. KC6HIO
GOD BLESS 73s
PostPosted: Sat May 21, 2005 1:16 pm
Steve,
Yes I did. It's now run by the Federal Way Amateur Club. I miss the fun I had with the repeater (0sometimes).
I live in Kent and noticed about a month ago dispatch started routing people to "records". At first I thought it was a cahnge of name for "Admin" (TG 37200) but that was not the case. I will nail it on a search soon but if you figure it out plrease let me know.
Jim
 Post subject: Kent PD Records
PostPosted: Sat May 21, 2005 8:52 pm
Hey guys,
Valcom recently changed a talkgroup to run names during peak times.
It is the old Narc 1 talkgroup 37424. I have heard it called stats, data, and records.
Stats and data is what I hear it called most often. It appears they are changing things a little. Give it a try, I'm sure you will find what you are looking for.
Records is usually the stations local computer, and is on their Admin talkgroup.
Jim, we have never talked, but I miss your repeater identifiers. It's kind of lame now. No activity.
Steve,
How are you doing? Are you still using the J-Pole?
I hope to hear you soon on the air.
I have been away for a while, but will get more involved in the future.
73
Vince.
kd7olp
PostPosted: Sun May 22, 2005 10:54 am
Vince,
Thanks for the Kent TG for Data. I have loaded it into my 5 scanners.
I only occasionally listen to my repeater. I have had many ideas for new IDs but I don't believe FWARC is using the WAV file function anymore. Some of the IDs took many days to construct as I mixed many sounds into them. I have occasional thoughts of constructing a new repeater but then work harkens! Somehow my priorities got all screwed up...
Jim
KA7GZR
