It is currently Wed Sep 09, 2026 2:32 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
PostPosted: Wed May 30, 2012 12:20 pm
Getting a very loud audible whine on 462.675 Mhz. I cannot tell you how annoying it sounds. It really sucks because it interferes with my scans of the GMRS frequencies. :)
If anyone is looking for a mystery to solve then head over to the Eastgate area in Bellevue. It's very loud here. It just started up in the last 48 hours -- wasn't present over the weekend.
It easily covers 30khz of the spectrum.
Quick note: every so often, the whine stops and gives way to just open static
PostPosted: Wed May 30, 2012 7:48 pm
Sound like it has 60hz buzz in it at all? Motorhome in the area??
PostPosted: Wed May 30, 2012 11:39 pm
No it had a pretty clean signal actually. Make no mistake, this was a *strong* signal. I would guess it from a hilltop repeater system. I didn't get a chance to drive around to see how far it went.
However -- as of 11:23pm it suddenly stopped. Either someone fixed their problem or the equipment finally gave up.
PostPosted: Thu May 31, 2012 8:30 am
2000-2001 models of the Wingard Sensor amplifier antenna's would go into self oscillation and attach themselves to local used frequencies (+harmonics of said freqs) and roll up and down around that freq. If you were within 25 yards and clear line of site to it you could see your radio rssi start to peak...
They would modulate the 60 hz from the RV power supply so if nothing is plugged into the power supply they could produce a clean carrier...
Just a thought...
PostPosted: Thu May 31, 2012 1:11 pm
The static/inteference is back of right now -- 2:10pm. The whine is not present at this time. Full-quieting into the Lake Hills area.
PostPosted: Wed Jun 06, 2012 2:58 pm
Pimp Daddy Radio
I had a strong full-quieting signal over on 148th and 520 on my 346T. Same thing at my place in DT Bellevue. This is definitely a powerful signal. Who's got some DF gear they want to test out? :chaingun:
PostPosted: Wed Jun 06, 2012 3:16 pm
I have a nice portable Yagi for 440mhz HAM but the signal is so strong it doesn't really DF well. I'm thinking [the repeater] is up on top of one of our local hills.
PostPosted: Wed Jun 06, 2012 3:31 pm
I do, but I work all day tomorrow then leave for North Dakota Friday morning, sorry. Unless someone wants to borrow it...?
PostPosted: Wed Jun 06, 2012 3:48 pm
Pimp Daddy Radio
Good point. If the crappy OEM antenna on my 346T can get a great signal, it's pretty strong.
PostPosted: Wed Jun 06, 2012 6:50 pm
I have a receiver with a 4 step attenuator.
I'll charge the batt and see what I see tomorrow.
PostPosted: Wed Jun 06, 2012 7:17 pm
Today was my day to go to Issaquah, otherwise I would check.
PostPosted: Wed Jun 06, 2012 10:02 pm
Probably an abandoned repeater.??
462.675 WA NOTE: 2 RPTRS ON THIS FREQ
462.675 WA GMRS, RADIO SHACK PRS-101 EMERG CHANNEL ch.ORG DOT
462.675 R UNK WA Snohomish EVERGREEN UNITS ch.COUNTY ____4375
462.675 110.9 R UNK WA King RADIO TECHS. ABC COMM?
462.675 118.8 R UNK WA King (N)
462.675 141.3 R UNK WA King (N) TOW? KAD3910
462.675 141.3 R UNK WA King NW COMMUNICATIONS? ch. ? ?KAE2575
462.675 151.4 R UNK WA King (HULK HAULERS)
462.675 71.9 R WA King Snoqualmie Pass SCANNER ALERTING NET (M.SARAN) 450-499, 400=MARK SARAN
PostPosted: Thu Jun 07, 2012 7:41 am
>400=MARK SARAN
Wow a real blast from the past.
PostPosted: Thu Jun 07, 2012 12:44 pm
Yeah, haven't you moved up to unit 420?
PostPosted: Thu Jun 07, 2012 1:22 pm
Solid carrier on handheld receiver I-5 at Columbian Way today
