It is currently Mon May 11, 2026 1:32 pm
 Post subject: Spokane 800
PostPosted: Fri Jul 29, 2011 9:32 am
So I still hear it on the air, but as you can see below, it's just an idle control channel:
FileVersion:6
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 001
System Name : Spovegas 800 P25
WACN : 0000A
Tower Number (Decimal): 101
Tower Number (Hex) : T0101
Tower Description : (null)
Control Capabilities : Data,Voice
Call Sign(s) :
Timestamp : Fri Jul 29 10:31:00 2011
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,821.18750,0.01250,-45.00000,"Confirmed",0.00625,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Frequency(/Slot),Hit Count
"00-2400","c",851.18750,806.18750,0
 Post subject: Re: Spokane 800
PostPosted: Fri Jul 29, 2011 9:51 am
Spovegas?
PostPosted: Fri Jul 29, 2011 9:55 am
Nicer than Spocompton...
PostPosted: Fri Jul 29, 2011 1:43 pm
Going thru there tomorrow. I hear the fire dispatch has locution now?
PostPosted: Fri Jul 29, 2011 2:46 pm
Next to the IDs.
Last time I seen Vegas was about 2000 AGL at night.
Not to get off topic or anything, but the captain over the intercom: "..keep the muzzle of your weapons pointed downwards".
(Tower Air military contract).
PostPosted: Fri Jul 29, 2011 2:53 pm
Can either of you check to see if that P25 repeater is still active? I guess there's a VHF and UHF repeater.
145.25
441.75
PostPosted: Fri Jul 29, 2011 3:14 pm
If you have a NAC, I can load it in the saber
PostPosted: Fri Jul 29, 2011 3:53 pm
Both are the default $293 NAC
PostPosted: Fri Jul 29, 2011 3:57 pm
k
PostPosted: Fri Jul 29, 2011 4:11 pm
145.25
441.75
I'm 127 miles north nowdays, so I can't.
PostPosted: Sat Jul 30, 2011 2:43 pm
Doesn't key up. I'll check my settings but the 145.250/144.650 is what I have with a 293 NAC, C4FM.
PostPosted: Sat Jul 30, 2011 2:49 pm
Thanks for checking. It's probably not online 24/7 or something... and/or the owner took it offline.
PostPosted: Sat Jul 30, 2011 2:59 pm
he has an anti spam email. I sent him one but can't find any info on his webpage or at least according to Artsci the machine has his call.http://n7bfs.net/~B.8dcole/
PostPosted: Fri Jan 13, 2012 9:15 pm
Still on the air, still idle:
System ID : 001
System Name : SpoCompton P25 system NAC 00A
WACN : 0000A
Tower Description : Idle Simo
Control Capabilities : Voice,Registration
Call Sign(s) :
Timestamp : Fri Jan 13 21:14:27 2012
-Tables
-Frequencies
"00-2404","a",851.23750,806.23750,0
"00-2442","a",851.71250,806.71250,0
"00-2575","a",853.37500,808.37500,0
"00-2617","a",853.90000,808.90000,0
