It is currently Fri May 15, 2026 4:34 am
PostPosted: Tue Dec 07, 2010 6:13 pm
So I am getting a bit curious about SAR operations in Washington state.
It looks like the primary communcations is on National SAR (155.16) in most areas plus the usual local channels?
PostPosted: Tue Dec 07, 2010 6:17 pm
Pretty much, I ran into a group here in Olympia that provides communications much like Mtn Wave does and they were using 151.625 with a tone. I think most every SAR group in the NW has 155.160 in their channel plan. Even Lewis County Sheriff uses it as a C/C occasionally.
PostPosted: Tue Dec 07, 2010 10:14 pm
YSO does too.
I've also noticed that the radio plans for snoqualmie pass area possesses that freq.
PostPosted: Tue Dec 07, 2010 10:25 pm
They call it 'SAR'; never heard anything on it...I think ski patrol uses it talking with Seattle Mountain Rescue.
PCSD has it as F-11, labelled "SAR", running CSQ.
AMR ambulance dispatches on it in King County.
PCOBS has it as F-3 in their portables, "SAR", also CSQ.
PostPosted: Wed Dec 08, 2010 6:58 am
I believe that this freq. is technically open to a lot of Agencies. When I was active with SAR we didn't use it much in Eastern Wa because some School District in Yakima County was using for their school bus drivers. This was quite a while ago.
PostPosted: Wed Dec 08, 2010 7:00 am
Snohomish County SAR operates on 155.415. Which in turn is patched to TG 1616 on the SERS 800 trunk system.
PostPosted: Wed Dec 08, 2010 7:47 am
Interesting info guys. In Oregon, we are kind of spoiled by having a statewide SAR channel on VHF...
PostPosted: Wed Dec 08, 2010 8:52 am
That school district still uses it with a tone of 179.9. The school district I'm thinking it might be has a bunch of new NB licenses so that problem may be alleviated here soon.
PostPosted: Wed Dec 08, 2010 4:27 pm
King County mostly uses 153.755. The only time I've ever seen 155.16 used is for large missions with units from multiple counties responding, and not always then.
PostPosted: Fri Dec 10, 2010 12:29 pm
Yup and Wil touched on this too. Ski Patrol uses it at Snoqualmie, channel tag "SPART" for Ski Patrol and Rescue Team. I've heard Airlift talking to them on it a few times when they pickup someone from the upper lot at Alpental.
PostPosted: Fri Dec 10, 2010 11:19 pm
Wonder what else changed since last year...When I was there Nov-Apr, Ch-5 was just tagged "SAR" in all the radios I had.
Updates?
PostPosted: Fri Dec 10, 2010 11:35 pm
Is that 155.805? Is it CSQ? Always wondered...
PostPosted: Sat Dec 11, 2010 4:29 am
Yes, thats correct. its CSQ on the receive side; some groups run a TX tone only because in neighboring states, there is a few repeaters with that as an input.
PostPosted: Sun Dec 12, 2010 1:49 am
I'm hearing a Med Com unit on 155.215 and Sheriff on 155.160 from Monroe. The 155.160 sounds like it's coming out of the south end of Seattle-Tac. Other listed SAR chnls are school buses. That's exciting to listen too!......:)
PostPosted: Sun Dec 12, 2010 8:49 am
This is why a state coordinated SAR channel is important :P
Users browsing this forum: No registered users and 15 guests
