It is currently Wed May 20, 2026 1:59 am
 Post subject: WHAT SCANNER
PostPosted: Wed Dec 15, 2004 7:43 am
HI All. New on here. Want to get back into scanning. Is an APCO-25 scanner necessary to hear all thats going on in the Seattle, King and Snohomish county area. :?: Thanks all w7ozx
PostPosted: Mon Jan 03, 2005 1:34 am
Jerry, in short, no, it's not necessary. It sounds like the digital modes are changing anyway, so it's hard to say that you may not need another radio in the future. The exception I believe is that the new Uniden radios are flash upgradable, so that should help to a point.
If you have money to burn, then go with the best you can afford (296,796) ... otherwise, a decent used Pro-90+ will work just fine. It just depends on what you want to listen to.
-Nick
Users browsing this forum: No registered users and 20 guests
