It is currently Sun May 17, 2026 3:33 pm
 Post subject: PSOPS S3 & S4
PostPosted: Wed Nov 10, 2010 9:25 am
Does anyone have the talkgroup numbers for PSOPS S3 and S4. I have searched the db and forums with no luck. I am also looking for the Pierce County Mutual Aid talkgroups MA PC1 and MA PC2 or there VHF equivalent.
Thanks in advance
Richard
Do you know Bunnery?
 Post subject: Re: PSOPS S3 & S4
PostPosted: Thu Nov 11, 2010 8:17 am
Nope, I have N1-N4 and S1/S2, but haven't ever seen numbers for S3/S4.
PostPosted: Thu Nov 11, 2010 9:00 am
They are apparently to be used in Pierce County just don't what the talkgroups are? I have seen them referenced in several ValleyComm doc's.
Richard
PostPosted: Thu Nov 11, 2010 9:55 am
Try 62992 and 63024. I can't receive them from here to confirm.
My understanding is that when you select PSOps S3 or S4, you're on the PierceCo system (not linked, the radio is really a defined PCo user). Likewise for N3/N4 and SnohomishCo.
PostPosted: Thu Nov 11, 2010 6:47 pm
Those talkgroups are S1 and S2 respectively on the King County TRS.
Richard
PostPosted: Thu Nov 11, 2010 9:51 pm
I agree with those being for King County. However looking at old notes from using Trunker on the Tacoma system during the protests at the Port of Tacoma when the military was moving equipment, I did show PSOPS S3 as talkgroup 62992. They had Seattle units assisting if I recall correctly at the time. I agree it seems quite a coincidence but may have been by design to use the same talkgroup numbers. They are both Moto II.
I also show 63024 as PSOPS S4. All my Trunker files are verified by me personally so I think this is correct. The signal is good tonight so I will start monitoring again when I can. This data is several years old.
Vince.
