It is currently Wed May 13, 2026 8:49 am
PostPosted: Fri Jul 30, 2010 9:37 pm
Noticed LEARN is busy tonight. I have it in my NORCOM/Eastside bank on my Pro-97 and was under the impression it was usually used for large incidents or to have several agencies able to communicate on one freq/Tg for a major incident. Tonight I'm hearing what is sounding like car stops in Pierce Co. and a heavy volume at that. Sounds quite routine and all different streets/locations being called out. and Why is it that I almost always only hear Pierce Co. on LEARN?? Thanks..
PostPosted: Fri Jul 30, 2010 9:39 pm
sorry for the typo i meant LERN...
PostPosted: Fri Jul 30, 2010 9:45 pm
X-52 or Target Zero emphasis tonight.
PostPosted: Fri Jul 30, 2010 9:48 pm
Awwww ok. Makes sense now with the sheer volume of stops I'm hearing going on..
PostPosted: Sat Jul 31, 2010 8:55 am
Usually listen to the 155.37 side of things... Pierce County does seem to use this quite a bit, routinely on weekends for the aforementioned activity plus anything that requires multi-agency coordination... as not everyone in Pierce is up and running on the trunked system...
Eric
KB7DQH
PostPosted: Sat Jul 31, 2010 11:11 am
And in the NorCom/Eastside area LERN and MARS are basically unused anymore except for communicating directly with WSP. PSOPS N1/N2, PSOPS S1/S2, and MA Snocom/Snopac channels are where I hear either PD or Fire (or joint operations) traffic.
I too hear LERN traffic from pierce county rebroadcast onto the LERN talkgroup on the 800 system...
PostPosted: Sat Jul 31, 2010 12:17 pm
800 Trunk systems are EXCELLENT LERN receivers!
I have heard traffic from as far out as Grays Harbor / Aberdeen area.
PostPosted: Sat Jul 31, 2010 1:35 pm
One of my fav's from our SE precinct
County Frank 5 to state on LERN
Ellensburg State, go ahead Frank 5
Disregard, King County 2 Frank 5 to Seattle state on LERN.
Guess that's what happens when you use a 4 site high altitude simulcast patched to a talkgroup.
PostPosted: Sat Jul 31, 2010 4:46 pm
Nice!
PostPosted: Sun Aug 01, 2010 7:40 am
It was a DUI emphasis when I worked down that way.
WSP was the 'radio' for it.
