It is currently Sun May 17, 2026 9:58 pm
 Post subject: MT May Issue Does Tacoma
PostPosted: Mon Apr 19, 2010 3:55 pm
There is an info piece on Tacoma - Pierce County in the new issue of Monitoring Times. It is a shame that the system is in such a state of change at this time with the merging of CF Fire.
PostPosted: Mon Apr 19, 2010 4:58 pm
Not to hijack the thread but there is good info on CAP also in this issue. :D
PostPosted: Mon Apr 19, 2010 5:33 pm
7500
PostPosted: Mon Apr 19, 2010 9:25 pm
I guess I should be showing 7600 since, by the time I got Yakima up, they weren't Yakking anymore....
PostPosted: Mon Apr 19, 2010 11:52 pm
The sidewalks do roll up early around there. At least you begin to see the experience of rebanding through the lens of Trunker. It may help when that stuff happens around here. If the fleet map is correct you will see AFS and Decimal groups provided they are using both types of radios. You can practice around here with system 0010 in Kitsap County which has both types of radios but isn;t rebanded yet.
