It is currently Wed May 13, 2026 12:09 pm
 Post subject: port of seattle fire
PostPosted: Fri Feb 19, 2010 11:50 am
does anyone know the fire dispatch for port of seattle fire i know they dispatch on on none trunk then switch to trunk tac 1 or 2 i think it is 453.500 or 453.400 can anyone help with this and tell me right frec thanks
 Post subject: Re: port of seattle fire
PostPosted: Fri Feb 19, 2010 12:33 pm
It's on the trunked system. I don't remember which, but they do multi select or all (announcement) TG or something. It's somewhere in the range of 816 and 976. If your scanner supports status bit, turn it on and you can see exactly which talkgroup it is. If it doesn't or you want to leave it off, just put 816, 848, 880, 912, 944, and 976 in and eventually you'll find it.
PostPosted: Fri Feb 19, 2010 12:38 pm
I don't know what that UHF frequency is, or if it's actually linked so anything, but it is definitely not the 24016 on the King County trunked system (although the 24016 on the trunked system is linked to a UHF freq).
http://interceptradio.com/s.php?sfreq=4 ... ddel=1&z=1
PostPosted: Fri Feb 19, 2010 12:45 pm
453.5000/123.0 (in our database)
PostPosted: Fri Feb 19, 2010 12:59 pm
thank for infor that helped
