It is currently Wed May 13, 2026 5:20 am
 Post subject: 787 in moses lake
PostPosted: Tue Jan 05, 2010 1:30 pm
I think the Boeing 787 001 is flight testing here in moses lake I Hear it on 123.325 FLT Test 5 :bowdown: :bowrofl:
 Post subject: Re: 787 in moses lake
PostPosted: Wed Jan 06, 2010 12:04 pm
You might search between 136 and 137 also!
PostPosted: Wed Jan 06, 2010 3:19 pm
The 787 landed yesterday and flight testing will begin Thursday if weather conditions allow.
I've attached photos of the landing courtesy of the Columbia Basin Herald.
http://www.instantimagegallery.com/iig/ ... AAuQ%3D%3D
Spectrum Communications, Inc.
526 S Locust Lane
Moses Lake, WA 98837
http://www.scml.us
http://www.insp.com
PostPosted: Thu Jan 07, 2010 2:24 pm
check out flightaware.com and flight BOE1. It shows a 787 en route Boeing Field to Moses Lake with 15 minutes left in flight. A good tool to see if the dreamliner has filed a flight plan.
PostPosted: Fri Jan 08, 2010 5:03 pm
WIth a delay! BOE89 is MAgpie
PostPosted: Sat Jan 09, 2010 2:38 am
I've been camping near Lake Wenatchee the past 5 days and have heard #1 flight testing everyday. I'm only hearing the 787 side. Been interesting to hear the problems and testing.
Also, getting check ins with SeaTac from commercial jets heading westbound 15-20 mins out from landing. Busy check in point.
PostPosted: Sat Jan 09, 2010 6:26 am
You hear anything on 152.915?
7/29/07- 152.915- No tone decoded. 3 guys were on here joking back and forth with each other about the WSP speed enforcement. I could listen to Air-6 calling out vehicles for the ground units, then switch to this one and catch color commentary about the way he called the descriptions. The guys on this channel mentioned "Air-6" by callsign, and noted the fact he'd recently been in the Tri-Cities area as well. Both either had scanners or two-ways, as I could hear the WSP traffic as they chatted. A license check shows this freq as being part of a network of "for hire" repeaters, but this was simplex traffic. Very strong in Leavenworth proper.
PostPosted: Sat Jan 09, 2010 5:38 pm
By summer there will be six 787s in test. Expect to see them come and go unpredictably, as weather and test requirements determine where to fly. There are at least four different paint schemes, and enough detail differences to make them all unique.
When the full crew gets aboard, the non-ATC radio traffic will dry up.
The 747-8 will fly sometime this winter...
PostPosted: Sun Jan 10, 2010 3:26 pm
from my understanding of it the 747-800 is going to fly around the end of this month I was told around the 20th
born to be wild
PostPosted: Sun Jan 10, 2010 11:14 pm
Just heard the other day it is suppose to be by the end of the month too.
PostPosted: Mon Jan 11, 2010 4:02 am
Has the 787 been sending on ACARS? I decode ACARS data here in Oregon and was wondering if it was sending anything.
