It is currently Fri May 15, 2026 5:47 pm
 Post subject: BC235XLT
PostPosted: Fri Dec 25, 2009 1:10 pm
Just picked up a BC235XLT. Having trouble getting the Snohomish County talkgroups to enter. Not sure if Fleet Map issues might be causing the problem. Is anyone familiar with this older scanner?
 Post subject: Re: BC235XLT
PostPosted: Fri Dec 25, 2009 1:24 pm
The 235 should work on Snohomish Co. If I recall correctly, press TRUNK once to enter trunk mode, hold down TRUNK until it beeps twice, select a trunk bank # (1-10), program in the frequencies, then press search to see if it locks on the control channel and receives stuff. If all that is ok then program in some talkgroups to receive.
PostPosted: Fri Dec 25, 2009 2:24 pm
Thanks for the info. I did a reset and started over. It's up and running now. Need to get the new scanner (BC346XT0) programmed now. Need to find my USB to serial adapter first. Thanks again!
