It is currently Sat May 16, 2026 1:15 am
PostPosted: Thu Dec 03, 2009 9:27 pm
THE BRAVERN, LLC
225 108TH AVE., SUITE 400
BELLEVUE, WA 98004-5782
WQKG275
452.3875 (457.x)
I think it's a single-freq repeater. You have to be near the complex to receive it as I get a major data channel on 452.375 from home.
I'll try to verify if it's just a conventional system. I'll be near there Saturday.
PostPosted: Thu Dec 03, 2009 9:38 pm
I work across the street I will check tmro for ya :)
PostPosted: Thu Dec 03, 2009 9:42 pm
Sweet thanks. Yeah I need to use my CloseCall more often. I didn't use it that much on the 396T. Not sure why, it just seemed like a pain to use - but I've figured out how to customize it with the 396XT.
PostPosted: Fri Dec 04, 2009 2:22 am
Close Call is pretty good, but even CC DND isn't the perfect combination with a trunked system that uses a dedicated control channel.
PostPosted: Fri Dec 04, 2009 2:14 pm
so far been quiet, mind you im in a building and have a 800mhz antenna but haven't so much as a beep from the frequency... I have friends coming to the area to use my corporate parking for the snoflake thing at the mall. If I end up wondering around I will flip on CC and see whats out there. not much point dooin it at work too busy and all I end up hearing is all the construction and cabby's hehe
PostPosted: Fri Dec 04, 2009 10:50 pm
Yeah their radios are only suppose to be 4watts so you may have to be right outside or inside the place. I'm stopping by there tomorrow, so I'll give it a check.
PostPosted: Sat Dec 05, 2009 10:07 pm
I didn't hear anything either. Hmm. I had close call on as well but nothing. Perhaps it's not used often..?
PostPosted: Sat Dec 05, 2009 10:41 pm
Nick, did you actually look at the FCC license in the database? It's a MOTOTRBO system.
PostPosted: Sat Dec 05, 2009 11:02 pm
Yes I did. Did something from the FCC database tell you this?
EDIT: Nevermind, I found it. I didn't think to check the emission type.
7K60FXE = MotoTRBO
PostPosted: Sun Dec 06, 2009 11:54 am
7K60FXE = MotoTRBO
AS per Glenn Mitchell:
Note: The emission codes 7K60FXD and 7K60FXE are for Motorola MOTOTRBO radios. These cannot be monitored.
Note: The emission codes 8K30Fxx and 4K00Fxx are for Kenwood NEXEDGE radios. These cannot be monitored.
