It is currently Fri May 15, 2026 10:46 pm
 Post subject: Bellevue AAR
PostPosted: Fri Feb 06, 2009 5:40 pm
Mostly went to check out the LTR system, but found a couple other things.
467.925 (D743) Victoria's Secret at Bellevue Square. Not quite as exciting as it should be. Simplex.
463.7375 (D155) Unknown construction. Lots of iron moving around, often on a crane.
451.2375 (D365) JCPenny. Also heard D026, sounded like maintenance guys. Repeated. Has a very long CWID (at least 20 seconds).
463.45 (67.0) Unknown taxi dispatch. Dispatchers transmit 110.9 PL, cabs 67.0. Heard units in the Bothell area as well as in Bellevue. Then I locked it out because taxis are the second most annoying thing after pagers.
I searched for the LTR system(s) under licenses WPXF825 (Bellevue Square Managers) and WPXF827 (Bellevue Place) since they're owned by the same corporation (they also own the Hilton and the Westin). There are a couple I couldn't find, and now, searching differently in ULS, I think there's a couple more I should add to the list for next time. I'm not sure if they're all lumped together, but I put them all in one bank since none of the LCNs that I found were duplicated.
451.7250
451.8250
451.9375
451.9625 LCN 13?
452.2125 LCN 14
452.6250 LCN 06
452.9750 LCN 10
463.5750 LCN 08--Probably the Waste Management system
463.6000 LCN 01
464.8750 LCN 02
464.875 I got on a Signal Stalker hit. I just looked it up and it's on WQAM384 (Bellevue Place) which is an IG license. Here's the talkgroups, and some notes:
0-01-045 Asking someone to bring up a "restroom closed" sign because the third floor men's restroom would be closed for the weekend for re-tiling.
0-01-075 Parking garage ops
0-01-085 Stuff going to room 2212
0-01-088 A lock was to be interrogated. Should be a simple interrogation. Another unit questioned if this was a guest request. 3 digit room numbers. (Unknown what crime the lock committed or whether or not it cooperated in interrogation).
0-01-100 Confirmed Bellevue Square Security. Inside and traffic.
0-01-101 Talking about work at the Hyatt
0-02-039 Front Desk calling Housekeeping
0-02-045 A child had been bleeding in the kid's cove and something about Guest Services. I think this one might be called Inside Maintenance. Mostly housekeeping ops.
0-02-055 Square61 talking to Square62. Something about the back door closing.
0-02-085 Calling to get it warmer in the Evergreen room. Not sure if it's on repeater 2, all I wrote down is -085.
0-02-100 Security for something. Possibly engineering and/or maintenance too.
0-02-102 Security?
0-02-118 Asking a unit to come to P5 for a supervisor's meeting. More traffic leads me to believe this is a security supervisor's channel.
0-02-125
0-02-128 Talk about a DJ and the dance floor
0-02-131 When he got back from his break he was going to do some stocking (or stalking).
0-02-139 Room 1104 needed a dog bead, and 10XX needed some shower gel. Male and female talking in an Asian language most of the time.
0-11-003
0-11-011
0-17-237 Parking?
0-21-107 Filling up with a lot of monthly parkers on P5
And some more on the "what do these antennas do" series:
Same shot as above, just different angle/altitude.
That panel just above the road sign--is it an 800 panel?
 Post subject: Re: Bellevue AAR
PostPosted: Fri Feb 06, 2009 7:18 pm
I think that the antenna shown in the third photo is an RFID reader. These are used to read the RFID tags that are found on transit buses and used to tell a tracking system the location of each bus. Also used to automatically open gates (such as at parking garages) and for toll and revenue collection. (At many airports, each of the shuttles (rental car, hotel, etc.) are charged a fee each time they make a pass through the airport pick-up drives).
Was this taken in the Metro Tunnel?
PostPosted: Fri Feb 06, 2009 8:19 pm
Yeah, trying to figure out where they transmit for the Tunnel IR's.
PostPosted: Fri Feb 06, 2009 8:34 pm
Search on radiax
PostPosted: Fri Feb 06, 2009 8:52 pm
Perhaps not, but I am thinking this http://www.lingeriebowl.com/seattlemist/index.html should do the trick.
PostPosted: Fri Feb 06, 2009 9:10 pm
Until recently, a technique known as "pipewrenching" was used to try and coerce a confession out of locks. This technique and other forms of torture were recently banned by the new Obama administration. :lol:
Seriously though, "interrogating" a lock probably refers to downloading data from a hotel type lock. These locks use access cards rather than keys to control access and have a small database contained within them that records the last twenty or so cards that have been used to operate the lock. These units are off-line and not connected to a network of any kind, so in order to obtain the data, you need to go up to the lock and connect something like a laptop or PDA to download the data. So, if something was reported missing from a hotel room, security could "interrogate" the lock to see who has recently been in the room.
Larger card access control systems, such as those used at the entrances to businesses, typically are "on-line" and allow reports of access activity to be generated centrally rather than requiring someone to go to each lock.
PostPosted: Sun Feb 08, 2009 9:20 pm
451.7250 LCN 17
451.8250 LCN 13
464.3750 LCN 18
464.7750 LCN 05
0-01-085 Hyatt Engineering
0-01-100 Bellevue Place or Hyatt Security
0-02-045 Bell Square Inside
0-02-055 Bell Square Maintenance
0-02-100 Bell Square Security
0-02-102 Lincoln Square Security
0-02-118 Lincoln Square Garage
0-02-125 Hilton Housekeeping/Engineering
0-02-139 Westin Housekeeping
PostPosted: Sun Feb 08, 2009 11:00 pm
Most Definately..... :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :hitit: :chaingun: :bowdown:
PostPosted: Sun Feb 08, 2009 11:21 pm
Apparently Seattle (well, Kent) is getting it's own "expansion team" this year in the LFL, "The Seattle Mist".
It's reported to be one of the most "successful" teams, as over 3500 "Season Tickets" (there are 2 home games per year) have been sold.
Therefore I propose that the fall games of the Seattle Mist become "official" activities for INW. I'm sure there are plenty of "frequencies" to search out, or something like that.
Another video from the LFL: http://video.google.com/videoplay?docid=6990329487395087560
PostPosted: Thu Nov 18, 2010 9:04 pm
Used these settings today; didn't pick up much.
01 463.600
02 464.875
05 464.775
06 452.625
13 451.825
14 452.2125
17 451.725
18 464.375
0-01-045 Possibly some sort of housekeeping
0-01-085 No notes
0-01-100 No notes
0-02-045 Bellevue Square Inside (miscellaneous maintanence tasks and lots of references to gondolas; pronounced gone DOE lah; probably this)
0-02-055 Bellevue Square Maintenance (Square units)
0-02-100 Bell Square Security (Boring. Security units from what I heard)
0-02-125 No notes
0-02-128 No notes
0-02-139 Westin Housekeeping (also boring)
