It is currently Wed May 20, 2026 8:50 am
 Post subject: Ft Lewis system
PostPosted: Thu Jan 01, 2009 11:00 am
I've seen some of the earlier threads here about the DOD 380 system, but wasn't able to determine if a trunking table was established or not that works, any ideas? GRE 600/pro197
 Post subject: Re: Ft Lewis system
PostPosted: Thu Jan 01, 2009 11:15 am
With the GRE500, I just set it to P25 Auto and went fro there.
PostPosted: Thu Jan 01, 2009 11:35 am
ok thanks, I can receive the 380.2125 cc pretty good here. The system is readable all the way to about exit 68 or so on I-5
PostPosted: Sat Jan 03, 2009 8:11 am
Can you guys let me know if you have any luck and how to monitor Fort Lewis Fire! I don't care about Range Control or MPs just Fire My Brother is a Fire Captain on Engine 2 they have 4 Stations and will soon merge with McChord due to BRAC . New Base will be called Lewis McChord Joint Military Installation. One Fire department with Army taking the lead.
PostPosted: Mon Jan 05, 2009 7:12 pm
So with the new alignment, any idea what's going to happen to the both systems? Is Mccord going to move to the 3xx range?
PostPosted: Thu Jan 22, 2009 10:09 pm
Haven't heard a fire tg yet
8107 seems to be one of the MP tg's
8530 has some interesting chat "Arabic role playing Captain" and so forth.
PostPosted: Fri Jan 23, 2009 6:38 am
When I worked at Ft Lewie fire was on VHF. Prolly still.
PostPosted: Fri Jan 23, 2009 8:04 am
DSTE nailed it in an earlier thread.
8115 is FortCom Fire Dispatch
8116 looks like Tac 2
8117 looks like Tac 3
8120 is another Tac
8121 is Madigan Disp
8122 is another Tac possibly for Madigan (MadCom)
8315 is Forestry Fire
8320 is Hazmat Responder
PostPosted: Fri Jan 23, 2009 8:48 am
oh cool thanks. I'm only able to hear the 380.2125 cc so I probably miss some of the comms. That and encryption.
PostPosted: Fri Jan 23, 2009 10:43 am
380.2125 is Site-02, the IR at Gray Army Air Field. you should get a vast majority of the traffic off this site, in my experience. Also, the ONLY encryption I've noted on the system is by one user on the "Gate Guards" talkgroup, 8104. The "Scouts Out" gate user is usually running in secure mode.
PostPosted: Fri Jan 23, 2009 11:33 am
Ok, I still get a tg like 8107 that will hang but no audio, not sure if the digital setting needs to be tweaked or if it can. How high up is the Gray site? It seems to boom into Olympia. I was thinking maybe they had something on Crawford Pk. I checked all your posts from last spring and entered the tg's. Did the McChord system trunk tables works out ok for you?
PostPosted: Fri Jan 23, 2009 2:15 pm
1- I'm not sure how to tweak the digital, if you can. I'll re-check my settings on the 500 and reply later.
2- The Gray site (I know right where it is) is 353', atop a tower that seemed around 35' tall.
3- I don't recall where I got the McChord tables, just that they work. They recently added another freq to the system though.
PostPosted: Fri Jan 23, 2009 2:36 pm
is it a problem to mix two systems like McChord and Lewis in the same scan list? I'm already up to bank 16
PostPosted: Fri Jan 23, 2009 3:13 pm
Dunno, never tried it.
PostPosted: Fri Jan 23, 2009 3:16 pm
ok thx
