It is currently Tue May 19, 2026 3:07 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Thu Sep 18, 2008 8:43 am
I'm programming up my new scanner and figured I would load it up with everything I could.
I see a TG for Bellevue FD Dispatch, 22384. I hear them getting dispatched on this TG but what TG's do they use for responding and operations?
The same question for Redmond FD. All I see is TG 18576 for Fire Command. If Redmond dispatched by Eastside Fire?
Thanks in advance...
PostPosted: Thu Sep 18, 2008 8:54 am
Nevermind, I think.
Seems as if both are dispatched by Eastside Fire?
Am I correct that the following depts are dispatched by Eastside
Bellevue
Redmond
Issaquah
Does anyone have a list of exactly which depts are dispatched by Eastside?
PostPosted: Thu Sep 18, 2008 9:08 am
Ya Eastside Fire handles just about everyone this side of the lake.
PostPosted: Thu Sep 18, 2008 9:10 am
Ok thanks.
What about Enumclaw?
I only see one TG for them, 32048
PostPosted: Thu Sep 18, 2008 9:39 am
*shrug* No idea. Not Eastside fire though.
PostPosted: Thu Sep 18, 2008 12:19 pm
I think enumclaw is dispatched by Pierce County Firecomm.
http://www.youtube.com/piercescan (Pierce County scanner recordings with action!)
Scanners:
Radioshack Pro 94
Radioshack Pro 97
Radioshack Pro 2051
PostPosted: Thu Sep 18, 2008 1:13 pm
EFD is dispatched by EPD
PostPosted: Thu Sep 18, 2008 8:10 pm
Eastside Communications (to be NORCOM in July2009) currently dispatches the following Fire Departments:
Bellevue Fire Department
Kirkland Fire Department
Redmond Fire Department
Mercer Island Fire Department
Woodinville Fire & Life Safety
Bothell Fire Dept (including the Snohomish County parts of Bothell)
Kenmore/Northshore Fire Department
Shoreline Fire Department
King County FD 10 (Issaquah and all the outlying county areas east of Bellevue to include Duvall, Carnation, Fall City, North Bend, City of Snoqualmie)
King County FD 50, Skykomish Fire (and approx. 6 miles beyond Stevens Pass)
Snoqualmie Pass Fire Department (and several miles over the pass, joint response with Kittitas County Fire)
22384 Eastside Fire Disp 1
22352 Eastside Fire Disp 2
22224 Eastside Fire Tac1
22192 Eastside Fire Tac2
22160 Eastside Fire Tac3
22128 Eastside Fire Tac4
22096 Eastside Fire Tac5
22064 Eastside Fire Tac6
22032 Fire Tac7
22000 Fire Tac8
21968 Eastside Fire Tac-9 (was Training Pool 3)
21936 Eastside Fire Tac-10 (was Training Pool 2)
PostPosted: Thu Sep 18, 2008 8:52 pm
thanks T68 for the info. :mrgreen:
Scanners:
Radioshack Pro 94
Radioshack Pro 97
Radioshack Pro 2051
PostPosted: Thu Sep 18, 2008 9:10 pm
EASTSIDE COMMUNICATIONS CENTER DISPATCHES FOR;
BELLEVUE FIRE DEPARTMENT STATIONS 1-9
BELLEVUE POLICE DEPARTMENT
BOTHELL FIRE DEPARTMENT STATIONS 42, 44, 45
SNOQUALMIE FIRE DEPARTMENT STATION 281
CLYDE HILL POLICE DEPARTMENT
DUVALL FIRE DEPARTMENT STATION 66, 68, 69
EASTSIDE FIRE AND RESCUE STATIONS 71-76, 78, 79, 81-83, 85-89
FALL CITY FIRE DEPARTMENT STATION 271
KIRKLAND FIRE DEPARTMENT STATION 21, 22, 24-27
MERCER ISLAND FIRE DEPARTMENT STATIONS 91, 92
NORTHSHORE FIRE DEPARTMENT STATIONS 51, 57
REDMOND FIRE DEPARTMENT STATIONS 11-16, 18
SHORELINE FIRE DEPARTMENT STATIONS 61-65
SKYKOMISH FIRE DEPARTMENT
SNOQUALMIE PASS FIRE DEPARTMENT STATION 291
WOODINVILLE FIRE AND LIFE SAFETY STATION 31, 33-35
PostPosted: Fri Sep 19, 2008 6:06 am
Thank you everyone for the info.
I figured out that Enumclaw FD is toned out by their own dispatch center on VHF. Which is patched on the Valley Com trunk using TG 32048.
I assume they only use one frequency for dispatch and operations.
PostPosted: Fri Sep 19, 2008 9:32 am
FCC Database shows an EXPIRED license for PCFD #26
KMA493
Located near Enumclaw
153.830 MO
153.890 FB/MO
154.355 FB/MO
Also found Enumclaw Hospital
464.000 FB2/MO (10 watts)
A few other oddballs:(All licensed to City of Enumclaw)
155.880
155.055
And listed as "90.19A PD Primary Dispatch"
154.875
155.010
155.050 (note is 5KHz off of 155.055 above - strange)
158.850
159.090
PostPosted: Fri Jan 02, 2009 8:53 am
22032 Fire Tac7
22000 Fire Tac8
Quick question on this. I know FD 50 operates on VHF xxx.190 (forget the exact freq) and not on the 800 trunk. Does anyone know if when they are dispatched is it also simulcast on 800? Or is there a an available TG that simlecasts all of the xxx.190 traffic?
Also. Which other depts that Eastside dispatches work of of .190?
I'm working on putting up a live Eastside feed so I'm trying to understand the small details.
-Thanks
PostPosted: Fri Jan 02, 2009 10:10 am
Skykomish operates on 154.190, pretty much exclusively. They are not patched to the rest of King County - pretty much no need. When they request mutual aid from Snohomish County, those units generally have a radio capable of 154.190 - no patching is necessary.
I believe that Snoqualmie Pass fire also still operates on 154.190, and when mutual aid is called from "down the way", then Eastside can create a patch to an 800mhz talkgroup (by request, if the responding unit doesn't have a VHF radio already).
Eastside is still using two-tone sequential voice paging for all departments, but that will probably be phased out later this year, in favor of alpha paging. 154.400, 154.190, 460.625 are still used for the voice paging.
PostPosted: Fri Jan 02, 2009 10:31 am
Okay thanks.
Just do I'm clear. Skyhomish FD and Snoqualmie FD is dispatched by Eastside, yes? And the tone used is 107.2?
Ya I hear GoldBar M54 always say they are switching over to "190" when they run mutual with Aid 295 (I think it's 295) Which I have to assume means they are going to the VHF radio freq 154.190.
