It is currently Sun May 24, 2026 5:52 pm
 Post subject: scanner data files
PostPosted: Fri Aug 29, 2008 3:35 pm
Thought I would Share some Scanner Data files with the masses, sometime people like that.
Here are my BcTool dumps for a bct15,996,246 uniden scanner.
Let me know any feedback you have - or if you enjoy having this data put up to assist you in your programming.
K7MHI-ScannerFiles.zip [162.17 KiB]
Downloaded 132 times
 Post subject: Re: scanner data files
PostPosted: Sat Aug 30, 2008 1:00 pm
I'll post my very basic Pro97 file for Seattle in a little bit.
PostPosted: Sat Aug 30, 2008 11:58 pm
Where's the amateur stuff from?
PostPosted: Sun Aug 31, 2008 7:28 am
I have been trying to upload my pro 97 file and it tells me extension .p97 is not allowed. ?
PostPosted: Sun Aug 31, 2008 8:11 am
What is a pro 97 file?
PostPosted: Sun Aug 31, 2008 8:47 am
It's a scanner data file for the radio Shack pro 97 scanner.
PostPosted: Sun Aug 31, 2008 12:49 pm
Zip it up first.
PostPosted: Sun Aug 31, 2008 1:06 pm
its just a dump of my HT and mobile yeasu radio's after looking at it I actually haven't updated that for a long while. I normally use just the transceivers for listen to ham not the scanners.
if your looking for more info on repeaters in the area i think Mike and Key club (google) has a large list of everything in Puget sounds. N7SNO/Cougar repeater (ch 2 is where I spend a lot of time as its family/friend operated) there or on the K7PP systems
PostPosted: Sun Aug 31, 2008 3:53 pm
By default the forum software allows generic image (gif, jpg) and archive (zip, rar) files. I changed it so it will allow files ending with .p97
PostPosted: Sun Aug 31, 2008 10:30 pm
Thanks Rich.
Here is what I have programmed in my radio. Feel free to let me know whats good or bad with it. Always trying to figure out how to hear everything more efficiently. I am in the southend and can usually copy everything except Snohomish (unless I get my antenna up higher and in the right spot.
King,Pierce,Snoho. VHF & 800 Mhz.p97 [52.8 KiB]
Downloaded 106 times
PostPosted: Sun Aug 31, 2008 11:00 pm
What does a .p97 file open with?
PostPosted: Sun Aug 31, 2008 11:01 pm
http://www.starrsoft.com/software/win97/default.asp
PostPosted: Mon Sep 01, 2008 8:18 am
might add that ...PRO-97 and PRO-2055 software if you didnt know.
PostPosted: Mon Sep 01, 2008 12:21 pm
Here's my file for the Portland area. Its probably not the best, but it works for me.
Sep 2008.p97 [52.8 KiB]
Downloaded 83 times
Users browsing this forum: No registered users and 15 guests
