It is currently Sat May 23, 2026 2:39 am
 Post subject: Flip Flop for Cencom
PostPosted: Fri Aug 29, 2008 11:10 am
Can anyone shed some light on why Cencom (Kitsap Co) has switched North/South freqs?
Is it permanent?
(Hope not, 'cause I get a lot of interference on the north freq.)
John
 Post subject: Re: Flip Flop for Cencom
PostPosted: Sun Aug 31, 2008 11:45 am
The LE1 output (155.685) that had been used for south dispatch had problems because an adjacent channel used by Fife PD was very strong in some parts of southern Kitsap County. The LE2 output (155.430) that was used in the northern part of Kitsap County did not have this issue, so they swapped the purposes of these channels. LE2 became the main channel for the southern and central areas, while LE1 became the main channel for the northern area. It's expected to be permanent.
PostPosted: Mon Sep 01, 2008 10:43 am
Thanks for the info, hopefully my interefence problems will abate. (I notice that reception varies significantly as we go from one season to the next.)
Users browsing this forum: No registered users and 39 guests
