It is currently Tue May 26, 2026 2:13 pm
PostPosted: Wed Jul 23, 2008 9:24 am
http://www.alaskasworld.com/Safety/Care ... ennial.pdf
In accordance with the FAA’s CFR Part 139, Airport Certification, Seattle-
Tacoma International Airport will be conducting a full scale emergency exercise
on Wednesday, July 30, 2008. The exercise entitled “Tri-ACE 2008” will be conducted in coordination with Alaska Airlines. A mock plane crash will be simulated and responded to test both SEA and Alaska’s emergency plans.
PostPosted: Tue Jul 29, 2008 2:19 pm
Starting late tonight, I'm going to set up my BC780xlt to capture TGID's from the CC-only mode. It'll be interesting to see what emergency TGID's get activated...
PostPosted: Wed Jul 30, 2008 1:14 am
Good idea; I'll do the same, recording audio too.
PostPosted: Wed Jul 30, 2008 11:54 am
I had most of the active/confirmed/non-related channels locked out. The only ones that came up were:
880 (FIRE TAC 2)
944 (FD ADMIN)
976 (MUTUAL AID POS (FIRE))
5712 (PORT CONSTRUCTION SERVICE)
12368 (Marine Facilities Management)
12208 (Marine Terminals All)
I don't think the last three are related. I haven't listened to anything yet. Also, 944 only had one dead key. Lots of activity on MA and TAC2, may or may not be related. Here's everything, 8.3MB zip file:
https://www.yousendit.com/transfer.php? ... Ukh2Wmc9PQ
PostPosted: Wed Jul 30, 2008 12:52 pm
Cool, thanks AT. I can listen to the logs while I'm at work. :)
I gazed at my hits before I left and I didn't see anything that stood out as new. I did see a lot of I-Call hits which is a bit rare on the Port trunk.
PostPosted: Wed Jul 30, 2008 12:56 pm
There was some confusion as to which talkgroups were being used after the first inital dispatch of the incident. Valley Comm Fire 1 advised the units to switch to the proper talk group and acknowledge. Several units responded that no one was answering on Port Fire Mutual Aid (TG 976) so they were to switch to state OPS 1, after several minutes everyone was advised that Port Fire Tac 2 (TG 880) will be the primary talkgroup.
The talkgroups that mostly used during this incident were:
TG 880 - Port Fire Tac 2
TG 976 - Port Fire Mutual Aid
TG 61808 - Med Comm 5
also used for adminstrative and FAA transmissions were:
TG 944 - Port Fire Admin.
TG 6448 - Port Emergency Command
PostPosted: Wed Jul 30, 2008 3:06 pm
I though of this while I was out today:
This doc wrote:
MUTUAL AID TO THE PORT OF SEATTLE/SEA TAC INTERNATIONAL AIRPORT
The Port of Seattle's 800 MHz system is not directly connected to the regional network's switch.
Therefore, all fire radios in the County that have the potential to be involved in providing mutual
aid to the Port of Seattle will need to have a mutual aid talkgroup programmed on their radios
that will place them on the Port's system so they can then be Talkgroup Merged into the incident
talkgroup on the Port's system.
The name of this talkgroup is MA POSFD
Anyone know if this was patched into something on 3D1C? I see in this doc it exists in their radios, but I've yet to see a talkgroup for it.
PostPosted: Wed Jul 30, 2008 9:53 pm
It's magic....
PostPosted: Wed Jul 30, 2008 9:55 pm
You mean the Merchandise Analysis & Growth Inventory Control system? Yeah, I use that all the time.
PostPosted: Thu Jul 31, 2008 9:40 am
MEECN (Minimum Essential Emergency Communications Network) Airborne Ground Improved Communications.
