It is currently Wed May 27, 2026 5:19 am
 Post subject: Medcom
PostPosted: Thu Apr 24, 2008 1:50 pm
I'm looking for a list of all the Medcom frequencies, their tones, and if and what talkgroups they are linked to. Intercept database is partial.
 Post subject: Re: Medcom
PostPosted: Thu Apr 24, 2008 5:32 pm
I don't know how to post links to previous posts, but if you search previous posts on "Medcom", you will see numerous messages, including one I left here about 8 months ago that lists all 10 medcom channels. Sorry to seem lazy, but I can't remember the actual order, and it is here in the archives.
They have added the 12.5 KHz channels between into the Medcom mix (although I don't know if they are in uses here in PNW).
Also, the most recent list I have seen from Part 90 even identifies all of the 6.25 KHz channels that fall between with Medcom channel identifiers as well.
PostPosted: Thu Apr 24, 2008 6:59 pm
here is all the Medcom Frequencies that i have been able to find, enjoy, sorry i just couldn't get the tones for ya :D
UHF Ultra-High band
Med 11 and above, are the new narrowband channels as designated by the FCC, and must be coordinated locally, and with the FCC. They are currently in limited use in Michigan, and will be slowly expanded across North America over the next few years.
Frequency Input License Type Alpha Tag Description Mode Tag
463.00000 468.00000 VARIES BM MED 1 Paramedics-to-Hospital FM Hospital
463.02500 468.02500 VARIES BM MED 2 Paramedics-to-Hospital FM Hospital
463.05000 468.05000 VARIES BM MED 3 Paramedics-to-Hospital FM Hospital
463.07500 468.07500 VARIES BM MED 4 Paramedics-to-Hospital FM Hospital
463.10000 468.10000 VARIES BM MED 5 Paramedics-to-Hospital FM Hospital
463.12500 468.12500 VARIES BM MED 6 Paramedics-to-Hospital FM Hospital
463.15000 468.15000 VARIES BM MED 7 Paramedics-to-Hospital FM Hospital
463.17500 468.17500 VARIES BM MED 8 Paramedics-to-Hospital FM Hospital
462.95000 467.95000 VARIES RM MED 9 Emergency Resource Coordination/EMS Dispatch FM EMS Dispatch
462.97500 467.97500 VARIES RM MED 10 Emergency Resource Coordination/EMS Dispatch FM EMS Dispatch
463.00625 468.00625 VARIES BM MED 11 Paramedics-to-Hospital FMN Hospital
463.01250 468.01250 VARIES BM MED 12 Paramedics-to-Hospital FMN Hospital
463.01575 468.01575 VARIES BM MED 13 Paramedics-to-Hospital FMN Hospital
463.03125 468.03125 VARIES BM MED 14 Paramedics-to-Hospital FMN Hospital
463.03750 468.03750 VARIES BM MED 15 Paramedics-to-Hospital FMN Hospital
463.04375 468.04375 VARIES BM MED 16 Paramedics-to-Hospital FMN Hospital
463.05625 468.05625 VARIES BM MED 17 Paramedics-to-Hospital FMN Hospital
463.06250 468.06250 VARIES BM MED 18 Paramedics-to-Hospital FMN Hospital
463.06975 468.06975 VARIES BM MED 19 Paramedics-to-Hospital FMN Hospital
463.08125 468.08125 VARIES BM MED 20 Paramedics-to-Hospital FMN Hospital
463.08750 468.08750 VARIES BM MED 21 Paramedics-to-Hospital FMN Hospital
463.09375 468.09375 VARIES BM MED 22 Paramedics-to-Hospital FMN Hospital
463.10625 468.10625 VARIES BM MED 23 Paramedics-to-Hospital FMN Hospital
463.11250 463.11250 VARIES BM MED 24 Paramedics-to-Hospital FMN Hospital
463.11875 468.11875 VARIES BM MED 25 Paramedics-to-Hospital FMN Hospital
463.13125 468.13125 VARIES BM MED 26 Paramedics-to-Hospital FMN Hospital
463.13750 468.13750 VARIES BM MED 27 Paramedics-to-Hospital FMN Hospital
463.14375 468.14375 VARIES BM MED 28 Paramedics-to-Hospital FMN Hospital
463.15825 468.15825 VARIES BM MED 29 Paramedics-to-Hospital FMN Hospital
463.16250 468.16250 VARIES BM MED 30 Paramedics-to-Hospital FMN Hospital
463.16875 468.16875 VARIES BM MED 31 Paramedics-to-Hospital FMN Hospital
463.18125 468.18125 VARIES BM MED 32 Paramedics-to-Hospital FMN Hospital
463.18750 468.18750 VARIES BM MED 33 Paramedics-to-Hospital FMN Hospital
463.18375 468.18375 VARIES BM MED 34 Paramedics-to-Hospital FMN Hospital
462.95625 468.95625 VARIES BM MED 91 Emergency Resource Coordination/EMS Dispatch FMN EMS Dispatch
462.96250 467.96250 VARIES BM MED 92 Emergency Resource Coordination/EMS Dispatch FMN EMS Dispatch
462.96675 467.96675 VARIES BM MED 101 Emergency Resource Coordination/EMS Dispatch FMN EMS Dispatch
462.96125 462.96125 VARIES BM MED 102 Emergency Resource Coordination/EMS Dispatch FMN EMS Dispatch
462.99375 468.99375 VARIES BM MED 103 Emergency Resource Coordination/EMS Dispatch FMN EMS Dispatch
If Prometheus was worthy of the wrath of heaven for kindling the first fire upon earth,
how ought all the gods honor the men who make it their professional business to put it out?
~John Godfrey Saxe
PostPosted: Thu Apr 24, 2008 10:53 pm
61808 is patched to 463.0 (179.9). I'm not sure if the patch is in place all the time; I only listen to 463.0 on a portable UHF radio (and mostly at night).
61840 "Might be patched to Medcom-5" thanks to Paul's notes on the KC TRS.
Seattle Fire uses 2000 and 2032 fairly often. 2000 is used more often than 2032.
Make sure you have 155.34, as AMR uses that all the time.
PostPosted: Thu Apr 24, 2008 11:03 pm
And here's the thread, just for reference:
viewtopic.php?f=1&t=1568
Just want to emphasize, yeah, I hear Airlift on Medcom all the time. I don't think they have radios that will get on the KingCo TRS. I think the Trauma/Medic One doctor at Harborview uses a UHF radio too, because I've tuned to 468.0 (the input for 463.0) and heard Harborview loud and clear. Medcom-01 is repeated from Squak Mountain and maybe a few other sites too.
Airlift's dispatch is on 155.295. Sometimes you won't hear them.
PostPosted: Thu Apr 24, 2008 11:57 pm
From FCC Part 90.20(d)(65)
This frequency is primarily authorized for use in the dispatch of medical care vehicles and personnel for the rendition or delivery of medical services. This frequency may also be assigned for intra-system and inter-system mutual assistance purposes. For uniformity in usage these frequency pairs may be referred to by channel name as follows:
Freq Base/Mob Freq Mob Chan Name
462.95000 ............................... 467.95000 MED– 9
462.95625 ............................... 467.95625 MED– 91
462.96250 ............................... 467.96250 MED– 92
462.96875 ............................... 467.96875 MED– 93
462.97500 ............................... 467.97500 MED– 10
462.98125 ............................... 467.98125 MED–101
462.98750 ............................... 467.98750 MED–102
462.99375 ............................... 467.99375 MED–103
- Also -
From FCC Part 90.20(d)(66)
For applications for new radio systems, the thirty-two frequency pairs listed in paragraph (d)(66)(i) of this section will be assigned in a block for shared operation under § 90.20(a)(1)(iii) or § 90.20(a)(2)(xiii) subject to the following:
(i) For uniformity in usage, these frequency pairs may be referred to by channel name as follows:
463.00000 ............................... 468.00000 MED– 1
463.00625 ............................... 468.00625 MED–11
463.01250 ............................... 468.01250 MED–12
463.01875 ............................... 468.01875 MED–13
463.02500 ............................... 468.02500 MED– 2
463.03125 ............................... 468.03125 MED–21
463.03750 ............................... 468.03750 MED–22
463.04375 ............................... 468.04375 MED–23
463.05000 ............................... 468.05000 MED– 3
463.05625 ............................... 468.05625 MED–31
463.06250 ............................... 468.06250 MED–32
463.06875 ............................... 468.06875 MED–33
463.07500 ............................... 468.07500 MED– 4
463.08125 ............................... 468.08125 MED–41
463.08750 ............................... 468.08750 MED–42
463.09375 ............................... 468.09375 MED–43
463.10000 ............................... 468.10000 MED– 5
463.10625 ............................... 468.10625 MED–51
463.11250 ............................... 468.11250 MED–52
463.11875 ............................... 468.11875 MED–53
463.12500 ............................... 468.12500 MED– 6
463.13125 ............................... 468.13125 MED–61
463.13750 ............................... 468.13750 MED–62
463.14375 ............................... 468.14375 MED–63
463.15000 ............................... 468.15000 MED– 7
463.15625 ............................... 468.15625 MED–71
463.16250 ............................... 468.16250 MED–72
463.16875 ............................... 468.16875 MED–73
463.17500 ............................... 468.17500 MED– 8
463.18125 ............................... 468.18125 MED–81
463.18750 ............................... 468.18750 MED–82
463.19375 ............................... 468.19375 MED–83
(ii) Except as provided in paragraphs (d)(66) (iii) and (iv) of this section, mobile or portable stations must employ equipment that is both wired and equipped to transmit/receive, respectively, on each of these MED frequency pairs with transmitters operated on the 468 MHz frequencies.
(iii) Portable (hand-held) units operated with a maximum output power of 2.5 watts are exempted from the multichannel equipment requirements specified in paragraph (d)(66)(ii) of this section.
(iv) Stations located in areas above line A, as defined in § 90.7 will be required to meet multi-channel equipment requirements only for those frequencies up to the number specified in paragraph (d)(66)(ii) of this section that have been assigned and coordinated with Canada in accordance with the applicable U.S.-Canada agreement.
PostPosted: Fri Apr 25, 2008 1:46 pm
Location: I'm hiding in Honduras -I'm a desperate man -Send lawyers, guns & money The shit has hit the fan
I talked with a Airlift dispatcher about this just a few days ago.
They have conventional 800, but not trunking. That is why they like to use State Op's 1, and 4 for air-ground.( who can blame them, I would do the same) The problem is a lot of fire guys dont want to hastle with messing around with their radios when a dispatcher can just patch a conventional Tac Ch with a 800 Talk group.
I also like to be able to have airlift in my ear at work in case something goes wrong.
The system is working, and I know that there is only so much room in those birds, but it sure would be nice if they could just get their 800 radios onboard with King/Sno county. AMR, and Rural Metro dont seem to have a problem.
Sorry for the Hijack :roll:
Respond on Tac 3
PostPosted: Fri Apr 25, 2008 2:08 pm
All the King County and Snohomish County TRS Radios have State Ops, Just the other day we were talking to ALNW from State Ops 1, no problem.
PostPosted: Fri Apr 25, 2008 5:46 pm
You are right, That is no problem....
The problem is, Not everyone Wants, Knows, or are Willing to play that way.
We could make a whole new multi-page topic on this stuff, and now that Im on vacation from playing Firefighter for a while, It could lead to a lot of upset people on both sides... So I try and only vent when I cant take anymore.... I still have a bit of time till I flashover :mrgreen:
Respond on Tac 3
