It is currently Mon May 25, 2026 12:26 am
 Post subject: King Co. TRS - ValleyCom
PostPosted: Mon Feb 04, 2008 8:42 am
Can someone confirm that primary data channel, 851.81250, is still active. This morning I noticed that it has went silent for me.
Did something chnage?
PostPosted: Mon Feb 04, 2008 10:21 am
It's on 868.425, one of the usual alternates.
PostPosted: Mon Feb 04, 2008 10:44 am
Ok. Thanks a lot.
PostPosted: Mon Feb 04, 2008 12:36 pm
I don't see that frequency listed for ValleyCom.
I'm confused. :shock:
PostPosted: Mon Feb 04, 2008 6:41 pm
Other web sites information on the trunk systems for this area is a mess. I have submitted several talk group updates in the past only to have someone change them to wrong information again. I gave up trying. This site is decent accuracy wise. Here is my list of frequencies that Trunker has found for the King County/ValCom simulcast site. This list may not be 100% as I have used Trunker for nearly ten years and it is possible some corrupt data may have slipped in over time. The d indicates data channel and v indicates voice channel. Some are used for both.
The problem with the internet is people do not verify information,they read it on a web site or book and take it for gospel.
v851.0875
v851.1625
v851.3625
dv851.8125
v851.9625
v852.1125
v852.6125
v852.8625
v853.3125
v853.4875
v853.6125
v854.0875
v854.2875
v866.3625
v866.3875
v866.9375
v866.9625
v867.3375
v867.4375
v867.8375
dv867.8625
dv868.4250
dv868.4500
Hope this helps.
Vince.
PostPosted: Tue Feb 05, 2008 10:05 am
Great. Thank you for the info. Much appreciated.
PostPosted: Sat Feb 09, 2008 10:39 pm
My original post described the voice and data channels. The most common alternate to 851.8125 is 868.425. I have also seen 867.8625 and 868.4500. These should be applied to the list of possible alternates.
Vince.
PostPosted: Sat Feb 09, 2008 11:10 pm
Right now they're listed as:
851.8125 KING COUNTY (SIMULCAST) (OVERFLOW CHANNEL)
868.4250 KING COUNTY (SIMULCAST) (CONTROL CHANNEL)
867.8625 KING COUNTY (SIMULCAST) (SECONDARY CONTROL CHANNEL)
868.4500 KING COUNTY (SIMULCAST) (OVERFLOW CHANNEL)
I know 851.8125 should be listed as Primary Control; but should the others be Secondary, Overflow, or Alternates?
Also, if you have any data on EPSCA or Seattle that'd be great too.
