It is currently Sun May 24, 2026 6:14 pm
PostPosted: Thu Sep 27, 2007 8:51 pm
Anyone have accurate information on Mason Co Sheriff and Shelton PD? Dispatches and Tacs? Databse info seems a little wonky with 3 dispatches and a tac all one frequency and some of these even with same tones.
PostPosted: Fri Sep 28, 2007 7:23 am
I can verify 460.225 as of last spring. For the SO. From the oyster beds of Potlatch state park!
PostPosted: Fri Sep 28, 2007 11:00 am
Makes sense to me...a common PL for the outputs of the dispatch repeaters, differing tones on the inputs to differentiate between 'North' and 'South' repeaters, and a direct/talkaround simplex channel with the same PL enabling the officers to overhear dispatch while chatting.
Pretty common setup...Or shall I make this a new project? 8)
PostPosted: Fri Sep 28, 2007 12:20 pm
Ya, I understand what you are saying. Though the databse listed more than one dispatch district on the same freq and tone. It's possible that's correct but I'm suspicious.
PostPosted: Fri Sep 28, 2007 3:00 pm
I've seen it done this way a lot...The county I worked for in California had repeaters on 6 different sites, all on the same freqs with varying PL tones on the inputs to select. Dispatch selected one site or all for dispatching, covering 3300 square miles and 6 districts. I doubt Mason Co has enough LEOs to justify more than one dispatch channel anyhow.
