It is currently Thu May 21, 2026 5:17 am
 Post subject: Ravensdale Fire Dist 47
PostPosted: Mon Mar 19, 2007 10:03 am
I'm tryingt to monitor the Ravensdale voly fire dept. I know that it's part of the King Co. trunk and that they are dispatched by Valley Com. I had programmed my scanned with
CC - 851.81250
TG - 35888
TG - 37488
TG - 37520
TG - 37552
TG - 37584
TG - 40240
Then I visited a friend of mine who is a FF there. He had his radio with him but I was not hearing dispatch or the TG they respond on. So, I clearly had the wrong TG's programmed. And possibly the wrong control channel.
Can anyone point me in the right direction?
PostPosted: Mon Mar 19, 2007 12:43 pm
Next time try the search feature on your scanner to lock in on the Talk-Group.
PostPosted: Mon Mar 19, 2007 1:58 pm
I did. There were way too many TG being used.
PostPosted: Mon Mar 19, 2007 2:38 pm
Have your FF friend key the Mike when you are in search mode. This can be done at a time when traffic is low.
PostPosted: Mon Mar 19, 2007 2:40 pm
Ya. We did that a couple of short time. But I never heard anything. And he did nto want to kepe keying the mic.
Anyhow. I think I have it figured out.
PostPosted: Mon Mar 19, 2007 4:57 pm
Ravensdale is dispatched by Valley Com. They use Fire 1-7. See this site for talkgroup info. You should hear them toned out on Fire 1. They are Stations 88 and 89.
PostPosted: Mon Mar 19, 2007 5:51 pm
So ae these the correct TG's?
38448 Val Fire 1 Pri Disp
38480 Val Fire 2
38512 Val Fire 3
PostPosted: Mon Mar 19, 2007 8:16 pm
38480 Val Fire 2
38512 Val Fire 3
Yes, those are the right talkgroups. Fire 4 (38544) is used for any full response. Fire 5, 6, and 7 may be used for additional fires. Ravensdale isn't very busy -- so you won't hear them toned out very often.
They may also used District 47 admin at times. 39248
PostPosted: Sat Mar 24, 2007 3:25 pm
I guess I am a little confused.
Yesterday I was scrolling through the Maple Valley FD web page and there it shows Engine 82 from their department covering Ravensdale. It even shows a picture of an engine which has E-82 Ravensdale on the side. Who really covers this area?
PostPosted: Sat Mar 24, 2007 8:12 pm
You're actually right. I was using the wrong terminology. Ravensdale is part of Maple Valley Fire's first due area. District 47 is Palmer/Selleck.
Still, they're all on the same talkgroups, and they all respond together.
PostPosted: Sat Mar 24, 2007 9:07 pm
You are right. They do use the same talkgroups, are dispatched from the same facility and work together well.
The abovementioned talk groups are the ones I listen to for Valley Comm and should provide you with many hours of listening.
Users browsing this forum: No registered users and 43 guests
