It is currently Fri Feb 13, 2026 5:54 am
 Post subject: I-call and I-tacs Q:
PostPosted: Wed Jan 24, 2007 10:12 pm
Do i need to program I-call and I-tacs in my scanner? What is it use for?
 Post subject: ICALL & ITAC
PostPosted: Sun Jan 28, 2007 9:35 am
When Public Safety puts up an 800mhz trunking radio system, they are *supposed* to put up repeaters on these frequencies to support out-of-area mutual aid (i.e., visiting fire or law enforcement agencies). They are stand alone repeaters, not connected to the trunking system - unless they are specifically patched to the trunking system to support an operation.
ICALL and ITAC-1 thru ITAC-4 are on the air in King County, and Sno County should be putting some on the air.
I believe there is still some talks going on between the three counties to coordinate at least the ICALL channel into a simulcast channel.
So, sure...plug them in. You will rarely hear anything, but if they are used it may be kind of interesting.
Brad/N7JGX
Whidbey Island, WA
PostPosted: Mon Jan 29, 2007 12:35 pm
Pimp Daddy Radio
I hear activity on I-tac 4 from time to time. I'm guessing it's up north though.
-Mike
