It is currently Thu May 21, 2026 1:09 pm
PostPosted: Mon Dec 25, 2006 4:33 pm
The past few months Ive been hearing air to ground traffic on 463.050mhz
traffic is between a base and helicopter where helicopter gives out lat/long reports etc on a vary strong repeater.
I think its a medivac helo judging from its comms but what company uses that frequency?
xjf79
Vancouver B.C.
bcd996t
discone
 Post subject: 463.050mhz
PostPosted: Mon Dec 25, 2006 8:44 pm
That could be a med-com freq for Air Lift Northwest in the Bellingham area
born to be wild
PostPosted: Mon Dec 25, 2006 11:34 pm
Do you happen to have any of the unit numbers used? Any units identified as "Omaha XXX" or "8000"?
PostPosted: Tue Dec 26, 2006 11:29 pm
yeah it sounds like it could be AirLift NorthWest
Helo just came up with Callsigns "Med-47"
40min out of seattle with 4 POB
Then gave vitals for its patient it had on board.
dispatch then sayed that AMR had been notified
damn powerfull repeater to be heard here in Vancouver
with radios squelch control turned to full quiet
http://airliftnw.org/images/maps/ALNW%20Base%20Map.pdf
24-Hour ComCenter:
(for flight requests only)
800-426-2430 (USA/Canada)
hummm didnt think we'd require US med air evac service a with our great medical system up here :roll:
PostPosted: Wed Dec 27, 2006 10:20 pm
Unless they've changed (?), Airlift NW uses the callsigns of "Airlift xx" and doesn't generally use AMR, they land directly at Harborview Med Ctr.
Anyone? I'm here on the valley floor, so I can't hear this one.
PostPosted: Fri Dec 29, 2006 12:00 am
Airlift does land directly on the pad at Harborview but it is a LONG walk/gurney push to the ER from the pad so normally they have an AMR unit for that phase of the transport. It's about a 1 city block distance.
Sometimes with a super-critical patient or no close AMR units available they will call for a SFD Medic Unit for the transport.
I thought Airlift had been using Med 2 463.025 for the North Sound communications.
Kerwin
PostPosted: Thu Jan 04, 2007 3:15 am
Kerwin
Many of the MEDCOMs are now linked, via WSP microwave.
I recently saw a map, but can't recall exact configuration.
Users browsing this forum: No registered users and 52 guests
