It is currently Wed May 20, 2026 8:49 pm
PostPosted: Mon Nov 06, 2006 3:21 pm
Trying to understand the whole control channel thing. Using the Snohomish Co Moto system as an example. I understand that there are primary control channels and secondary control channels. Then there are some other frequencies. I assume these other channels are used for transmitting the actual data? And the control channel is where the scanner gets the info on how to track the conversation?
Also, I see there is a West and East Simulcast. Both with control channels. I'm not sure if I should program both primary control channels in to my scanner or not. Is there reasons on why I would or would not want to do this?
And lastly, I see there are frequencies for Deer Creek IR and North Mountain IR. But no control channels listed. What are these?
PostPosted: Mon Nov 06, 2006 4:05 pm
what kind of scanner do you have is it tracking?
PostPosted: Mon Nov 06, 2006 4:07 pm
bc246t
PostPosted: Mon Nov 06, 2006 4:26 pm
There are 26 Freq. in the Snohomish County 800 system, I entered all 26 and then chose what TG I wanted to listen to. Is there any reason that I did not need to load all 26 freq. ? I have a BC 895 XLT and I receive everything I want to listen to from Lynnwood.
This is why i get confused when people are talking about Contron Channels. With the Snohomish County System just load everything. Can someone explain differantly?
PostPosted: Mon Nov 06, 2006 5:00 pm
My BC246T has the ability to track the frequencies via just the Control Channel. So, I don't have to load all the extra frequencies used.
I jsut want to understand the differenct in using the West or East trunk. Should I used both Control Channels? If I don't, will I miss some traffic?
 Post subject: RE: Control Channels
PostPosted: Tue Nov 07, 2006 5:25 pm
I have both the east and west freqs. in my Pro-97 I just put in a conventional freq in between the two systems so they can be in the same bank. Seems to work fine. Seems to get all the TG ID's just fine.
PostPosted: Tue Nov 07, 2006 6:48 pm
With just the control channel in you have more room in your scanner.
