It is currently Fri May 22, 2026 6:03 pm
PostPosted: Wed Sep 20, 2006 2:09 pm
This has been a very annoying problem since I got my radio shack pro97. The only work around I have found so far is either to hit "Scan" or lock out the frequency.
Has anyone else experienced this, or know of a different workaround for the problem ? I programmed this receiver by hand - I did not use any programming software.
Any information would be appreciated. Thanks in advance.
Peace
PostPosted: Wed Sep 20, 2006 7:07 pm
do you have it in MOT mode
 Post subject: PRO 97 scanner
PostPosted: Wed Sep 20, 2006 9:59 pm
The scanner display indicates the scanner is in motorola mode. m
Peace
PostPosted: Thu Sep 21, 2006 6:57 pm
make sure your talkgrou bank is set for montrola
PostPosted: Fri Sep 22, 2006 8:55 am
Hi Renton,
Thanks. I have Snohomish system in Bank 0 and yesterday went through the frequencies to make sure they were all set to Motorola and that seems to have made the difference.
Have a great one :)
Peace
PostPosted: Sat Sep 23, 2006 5:49 am
any time
