It is currently Sun May 24, 2026 11:12 am
 Post subject: Tacoma Trunk
PostPosted: Mon May 10, 2004 1:16 pm
I know Tacoma has a 800 trunk system. I did have the control channel as the following. ( 867.9875 ) Do anybody know any other control channels for them. I had problem picking them up this morning. I can pick them up from Puyallup.
I did here on Tacoma N Radio (460.150) they were having trouble with it being scrathy. Told the officer to use South dispatch or use a regaular potible.
Tacoma N PD Dispatch 52176
Tacoma S PD Dispatch 52304
54096 some sort of Fire Channel
Unable to pickup the Tac channels.
Michael R.
AD7TH
PostPosted: Mon May 10, 2004 5:50 pm
They switch control channels:867.9875 and 868.2500 are the two I have seen them use most but I have all the freqs. programmed in just in case.
52176-N. Tacoma dispatch(simulcast pretty regularly)
52304-S. Tacoma dispatch
52272-S. Tacoma Tac
52208-Tacoma Data
54704-Tacoma Fire dispatch(somewhat active)
54672-Tacoma Fire(somewhat active)
54096-A.M.R. Medics(very active)
53168-Tacoma refuse(very active)
53200-Tacoma refuse(very active)
53360-Tacoma solid waste/recycle(very active)
53680-Tacoma Maint. Ops.(very active)
53296-Tacoma water Ops.(very active)
None of these are confirmed but are what I have "figured" out so far.
PostPosted: Mon May 10, 2004 9:02 pm
867.98750
866.78750
866.81250
866.83750
866.86250
867.16250
867.18750
867.21250
867.23750
867.26250
867.46250
These are what Freqs. i have programed in any others i'm missing?
Michael R.
AD7TH
PostPosted: Mon May 10, 2004 9:17 pm
Here are the freq. I have(You are missing 868.2500 wich is a c.c. at times)
866.7875
866.8125
866.8375
866.8625
867.1625
867.1875
867.2125
867.2375
867.2625
867.4625
867.9500
867.9875(c.c.)
868.2500(was c.c. yesterday)
868.3250
 Post subject: Tacoma trunk
PostPosted: Tue May 11, 2004 9:26 am
add talkgroup 53520 to tacoma refuse :)
PostPosted: Tue May 18, 2004 8:51 am
I also have
866.4875
866.7625
866.7825
866.8625
These may be the Puyallup system however.
PostPosted: Tue May 18, 2004 6:42 pm
Are there any Apco25 talkgroups on this system? I have a reletive in Tacoma who's looking for a good trunktracker scanner, and was wondering whether I should reccomend a digital bearcat or Pro-96.
Thanks in Advance.
PostPosted: Tue May 18, 2004 7:02 pm
Any digital on Tacoma is encrypted. Don't bother with a P25 radio. Won't help at all.
PostPosted: Tue May 18, 2004 8:04 pm
Thanks for the tip Sean. Looks like a Pro-93 or 95 then...
Cheers,
PostPosted: Fri May 21, 2004 6:02 pm
Encryped?? Seems to be working fine right now???
PostPosted: Sat May 22, 2004 6:33 am
Most of their traffic is analog. Most of the traffic you are hearing now is just patched UHF traffic. Look at trunker, and you will see almost all the traffic is analog and patched.
PostPosted: Fri Sep 10, 2004 4:28 pm
I have also picked up 52240 - TPD N. Tac (simulcast)
52272-S. Tacoma Tac
52208-Tacoma Data
