It is currently Tue May 26, 2026 10:05 am
PostPosted: Mon Jul 10, 2006 7:36 pm
Anyone have the correct offset, base, and spacing for McChord airbase? All the frequencies are correct as listed and it appears all talkgroups are digital. The control channel is 3600 baud and it is a Motorola system.
Thanks for any help.
PostPosted: Mon Jul 10, 2006 8:24 pm
try
406.100
12.5
380
 Post subject: After some math...
PostPosted: Tue Jul 11, 2006 10:58 am
per Trunker: 407 / 25 / 380
PostPosted: Tue Jul 11, 2006 1:09 pm
I agree with FlashP that's what I programmed into the BC396T and it works fine.
Michael R.
AD7TH
PostPosted: Tue Jul 11, 2006 3:20 pm
Thanks for the replies guys, I used 407 / 25 / 380 but it did not work. I was using a pro-96, I will recheck everything but I am out of the area now. Thanks Again.
PostPosted: Wed Jul 12, 2006 8:11 am
If you've got the Pro-96, make sure you set the table option (Func 5 if I recall)
PostPosted: Wed Jul 12, 2006 8:17 am
Speaking of McChord, can anyone explain how to listen to Fort Lewis Fire Dept. They have 5 Stations on Post and cover 25 miles of I-5 that is theres and most of the time they are first in with Dupont. They are lucky if any Dupont rigs even show up with a full crew.
PostPosted: Wed Jul 12, 2006 1:17 pm
I think they were still on the VHF when I worked there in '04, even after the police dept and gate people were on the 400 trunk.
